Do you mean the power transformer inside it is missing?
Do you have the schematics / Service manual?
As there is no digital inside the CS-5, I’m pretty sure the power transformer would be a simple 15-0-15 Transformer (Just a guess for now) but see if you can get the schems before I take my CS-5 apart to check for you ;]
sheeesh… I don’t really like taking apart perfectly working mint gear for no reason… but for you I will.. just send me some Black Truffles or Some good french red wine as payment.. ;]
Yes, I was surprised by the 22-0-22.. I’d be pretty sure it would run on something less than that.. even 15-0-15’s measure a fair bit higher with no load.. and to be honest, I’d probably try one of those first… you generally can’t hurt something by under powering it.. and the CS-5 sure does not seem like it pulls a lot of current. ( ie - it runs very cool)
Why it was without it’s power supply in the first place however is the big question? Maybe it blew up? Maybe something is wrong with the synth?
If you get a proper transformer, disconnect the synth from the power PBC (The one in the pic), and check the output from the power PCB (after the regulators etc) before you plug it all together… those trimmers are probably for the ±15Vdc adjust.
Hi, i have the real story of this synth: when my friend have found it, he went at his home to test it, and he didn’ t saw that the power is 110V… and he plug it in 220 Volt… the synth made a little sound and… pwwwof, no sound… He asked another friend of me about the power supply et he took of the transfo. I have it now. All fuses are clean.
I tryed a 15/0/15 transfo, there is no synth sound but i can hear LFO and the LED supply is OK.
Try some simple measurements… is it spitting out CV from it’s CV out (If so, does it change with different keypresses etc)? Is the trigger out working (Short to ground trigger)
If not, maybe a whole heap of op-amps got toasted.. I think there is one big custom chip inside the CS5.. I H O P E that is OK.
I think from here on in, you’ll need a oscilliscope to find out whats else is going on…
I actually got hold of an original CS-5 Service manual.
(I do have a bad habit of collecting manuals & service manuals for stuff I have)
If you are still working on this, and have any specific questions, let me know, I might be able to help you out.
And before anyone asks for me to scan the whole manual, I’ll preface by saying it has many fold out inserts etc and one massive fold out block diagram / schematic.
