Midibox64seq V2
Hello!
A little information would be needed on the uCapps not is not entirely clear how and which software which links to be done in order to midibox64seq v2 can do it!! Someone feltehetné information, drawings, hex! 18F452 has to do with that at home. Thanks in advance! Luis
It is suitable for display???CTC LCD Display C240L02YBN00 2X40LINE x Char 1 STÜCK | eBay
Hello!
I have a yamaha module db50xg it would be good to midiboxseqV2??
thank you
MIDIbox SEQ V2 is a pretty old software, it won’t be supported anymore.
Why are you not upgrading to at least V3 (which is better documented)?
Anyhow, MBSEQ V2 is good for any MIDI device - but the possibilities are very restricted compared to V3 (or V4 of course)
Thanks for your response!
There are all the parts at home, I’d just like to know how it works. The v3 core to the panel is not good, to my knowledge. So if db50xg sound module can interface with V2?
Thank you, Louis.
I’m sorry now I see that seq V3 18F4620 core panel works! Instead of a five-18F4685 18F4620 Leht use? I do this at home. If yes then to collect the information. Thank you.
It is suitable for display! If so you’re likely to order!
The panels are now finished! Start with the implant!
I think they should add!
Egy kép!
I set the control panel for it! I hope it will be good instead of the rotary push-button design is good I think it is??
Hello Louis!
Even a few hours of work done!
Develops a thing! SEQV3
Yes a midibox seq v4 will work with a db50xg. In any case the seq v4.075 with an lpc17 core. I built a db50xg into a midio128 controller. Software in the programming forum.
