Midibox64 LC Variant
I have decided to build a variant of the low cost version of the Midibox64
It would include 2 AINx4’s and one Core
I would use 24 faders, 22 pots, 7 analog rocker switches, and one special pot.
Does this sound plausible?
Thanks
Kurt
Hi Kurt,
MB64 cannot emulate the Logic Control Protocol - however, without the large display it doesn’t make much sense anyhow, and most MIDI software provides a good integration of such a generic controller that you are planning to build.
I would suggest to add at least one DINX4 module (or one 74HC165 on a breadboard) for at least 8 buttons. This allows you to control special functions of your sequencer (e.g. Play/Stop/Record/…)
Also Solo/Mute buttons can be very useful
TK and Kurt- FWIW, I didn’t have much trouble moving the display elements around on a 2x40 using the MB64 files, and I barely know what I’m doing :wink:
I’ve played with the main display page layouts, but there’s lots of stuff that seems like it would need to be moved around to use the wide LCD. Nothing frightening, just a bunch of nudges and added characters. I’ve been fighting with some button mode changes the past couple nights, so the LCD offset thing is a fond memory.
Now that I’ve seen Nuendo’s ability to transmit the mapped generic remote element’s MIDI messages from the program, I don’t see much reason to go LC either, and the MB64 code seems written to be customized.
I do like the MTC display and the track metering, but there’s always MIDIMon for one of them.
-George  Â
