a)I need 7809 or 78L09 for SID 8580 and caps 6,8nF (poralised or ceramic one?)
For the you SID 6581 will need a 7812 (78L12 will also work) and 470pF “Styroflex” caps.
For the you SID 8580 will need a 7809 (78L09 will also work) and 6,8nF “Styroflex” caps.
Styroflex caps have low tolerance (2,5%) and are NOT polarized.
b) How many C64 psu do i need to feed 2MBHP_CORE&2MBHP_SID? (in the midiboxSID step B pic it seems theat all modules are connected to 2 PSUs)
One PSU is sufficient for 4 Cores and 4 SID modules.
c) What kind of components do i need to build the “small circuits” to optimized psu? (board 1000holes, 1x470nF/50V ceramic?,1x1N4001)?
Just take a look at the schematic:
http://www.ucapps.de/mbhp/mbhp_4xsid_c64_psu_optimized.pdf
A small peace of breadboard should be enough.
d)In this schematics of the circuit mentioned above there are 2 power switch: do i use two or can i connect the circuit to one?
It’s only one switch with two switches
(Don’t know how these are called in english…)
TIP: Just reuse the original C64 switch! It’s such a type of switch.
e)SID6581 and SID 8580…no mod. to psu board, is it right?
Right, if you stuff every SID board with the appropriate voltage regulator (7809/7812), ther is no change needed.
f) What is the difference between B40C800 and B80C800? In the core web page, in the compnent list B40C800 is required but in the txt file (order list) i find B80C800.
The first number (before the “C”) is the maximum input voltage for the rectifier. So both are OK (40 Volt max. rating is more than enough).
But if you use the 64 PSU schematic, you won’t need them on the core board because the PSU supplies already 5VDC.
Raphael
