yodabe
September 13, 2011, 10:22pm
1
Midibox TWINsid is a light midibox sid v2 on three pcb wiht only 2 sid chip for stereo sound
and a control surface for the clasic parameter (env flt …)
Midibox twinsid features :
Clasic 100x160mm pcb
2x16 lcd screen
The main board pcb integrated :
1 x psu parts (12v or 9v jumper setting)
1 x core module
8 x bankstick (7 for 896 patchs 1 for 128 ensemble)
1 x ltc module for midi thru and second midi out
2 x sid module
The SR board integrated the din and dout module
The CTRL board have 13 pots and 13 switchs for an easy programming
The enclosure and the pcb Layout coming soon …
Best regards
Pascal
m00dawg
September 13, 2011, 10:29pm
2
Looking snazzy! Looks like you put a good chunk of work into etching all that yourself. I certainly can’t make my own boards look that good Excited to see the enclosure!
yodabe
September 18, 2011, 7:20pm
7
thx all
enclosure preview in 3ds file
m00dawg
September 21, 2011, 12:16am
11
This is all great stuff! Have you thought about putting some of this on the wiki as well?
yodabe
September 21, 2011, 12:30am
12
yep of course !
i need before to create a soldering guide …
yodabe
September 22, 2011, 12:16am
13
i remove the files ! have no wiring the shift Up/Down button :frantics:
see soon
bruler
September 23, 2011, 8:13pm
14
This is really great, think I’m going to put my 6581s to work
yodabe
October 22, 2011, 12:34am
15
V1.2 is done
i have add a new serial registers for 3 new switch (shift up and down)
Best Regards
Pascal
yodabe
October 24, 2011, 11:03pm
16
v1.2 files
Best regards
Pascal
[twinsid mainb 1.1.pdf](< base_url >/applications/core/interface/file/attachment.php?id=9281)
[twinsid srb1.2.pdf](< base_url >/applications/core/interface/file/attachment.php?id=9282)
[setup_6581 01 twinsid.HEX](< base_url >/applications/core/interface/file/attachment.php?id=9286)
[twinsid ctrl a 1.2.pdf](< base_url >/applications/core/interface/file/attachment.php?id=9287)
[twinsid ctrl b 1.2.pdf](< base_url >/applications/core/interface/file/attachment.php?id=9288)
Well done! It gets nicer and nicer. Did you redo the enclosure as well? Wonder how much Ponoko wants if they make one…
yodabe
October 25, 2011, 12:43am
18
yep -)
the plan are send to the cnc laser cutting industry
one of my friend work on this sector that’s good for me
i wait for …
