I am about to start building a new Midibox SID V2. But before I start I need to clear some points, and specifically related to the power supply of the Midibox SID.
I have bought the kits from SmashTV and the PCBs are : Core is CORE_R4D, and SID is R3A.
All the questions are related to the document : mbhp_8xsid_c64_psu_optimized.pdf.
You specify for the power main circuit to use a B40C800. Is it equivalent to a W08G ?
You show in the schema to remove the regulators on the core module (7805), is it the only thing to remove ? I mean nothing else is to remove for the supply part on each core module ? As I am using the kits from SmashTV there is a regulator and a bridge rectifier on each core module, so do I need to connect them ? If not what connections do I have to make ?
You show also a connection between the core modules on J11 connector where VS and MI from the master core module goes in each slave module also on VS and MI. Is it correct ? I mean shouldn’t it be VS and M O from the master core that goes in each slave on VS and MI ?
Now for the SID modules power supply. You show to use a 7809 regulator on the main supply circuit. Does this mean that we also have to remove it from each SID module as for the core modules ? If so, do I have to make a bridge between IN and OUT+ as for the core modules ? And same question as for the core module, for the bridge regulator, do I need to connect it and if not what connection do I have to make ?
Again for the SID parts, you connect each Vd pin of the SID modules to the 14VDC pin of the power circuit. But where do I connect the Vs pin of the SID modules ?
Thank you very much for your help.
Best regards from France ![]()
Germain
