Hello. I have a problem with the DIN module. After starting the whole set in configuration:
- Core R4D, SID R3A, DINX4, LCD 2x20, mios 1.9g, PIC 18F452 and 4620 tested and different pcb-s
- Connections according to the scheme: MIDIbox SID V2 CS DIN map) as a attached jpg
the "select 1-5" buttons and encoder menu works fine. The "menu" button works like a "back" button. But the "Up / CC", "Down / Edit" and "Shift" buttons don`t work :(
Where is the problem, what I’m doing wrong ? Please help ![]()
