MIDIbox SID V1.6 alpha1
Hi *,
Due to requests I’ve decided to release an alpha version of MIDIbox SID V1.6, which is now available in the download section in parallel to the old (and stable) V1.5c.
See http://www.ucapps.de/midibox_sid_changelog.html
The final v1.6 will be released in some weeks or months…
Please report bugs here!
Hi Thorsten,
great set of new features :slight_smile:
I just transferred my custom settings to 1.6 and uploaded it. The issues I noticed so far are display-related:
When switching between the different SIDs, the patch name is not updated before you either go up and down one patch or enter a menu.
When you are on the main page and enter a menu by turning an encoder or pressing a CS key it seems that the second line is not cleared properly. Every fourth character of the patch name remains where normally the spaces between the parameters should be. This doesn´t appear when going through the menu to the page, but I suppose the reason is that in the main menu there are already spaces between the Menu names.
Can you reproduce these or have I made a mistake while porting my customizations?
Seppoman
Hi Seppoman,
too bad that I just have release alpha2 :wink:
Could you please check it with the new version?
See also: http://www.ucapps.de/midibox_sid_changelog.html
Hi Thorsten,
perfect, both display bugs gone :slight_smile: :slight_smile:
Thanks a lot,
Seppoman
Hi Thorsten,
ok, the next one, I suppose you didn´t see it on a 2x20:
on the name page (from Cfg menu) the second half (2x40) of the second line isn´t cleared after the “<   >   Del Ins Clr”.
Seppoman
Just another blind change added (-> cs_menu_exec.inc), main.hex and main.syx are up-to-date again
/edit: last change for today in cs_menu_exec.inc and cs_menu.inc (this time not “blind” :wink:
hello,
first i want to report that it sounds awesome. The new ENV. possibilities  are unbelievably. Thanks for this wonderfull toy.
One thing i recognized in v1.5c but never asked, the names for the CC´s in the WT are not displayed anymore!
chriss
Thanks Chriss! :slight_smile:
yes - the CURVE parameter is unexplored territorial, I see a lot of potential for fresh new SID sounds :slight_smile:
CC names: they are allocating too much internal memory (more than 1k), which should be free for upcoming features, therefore I’ve disabled the strings. Sooner or later I will provide an option which allows to store these strings in an external BankStick. By doing this, the strings could also be longer than 12 characters and therefore more readable
Hey T
from the changelog:
support for optional CBM8580 filter switch (jumper) which can be connected to pin RC.3 (CORE::J6::SI). This mechanism has to be enabled with CBM8580_FILTER_SWITCH in main.asm — it’s disabled by default! The pin number is free definable. A 10k pull-up should be added to this pin, this is already the case for RC.3 when you are using the original MBHP core module. Jumper open: 6581 filter, Jumper closed: 8580 filter
What does this do? and the part where u say “when you are using the original MBHP core module” implies theres another kind of core module about ? Is that V1? Confused…:stuck_out_tongue:
Ta
Dan
Hi Dan,
no reason for beeing confused. This is a feature for a guy who wants to switch between 6581 and 8580 w/o uploading a reconfigured application.
The note about the core module is for people who design their own layout. If they also want to switch between the filter algorithms, they should not forget this pull-up resistor.
cool, does that also require some modification or switch for the caps on the sid board itself? and of course the powersupply?
Hello,
I think this little apl. was for me…:slight_smile:
Me only wanted to switch between 2 Sid boards, supportet by only one Core.
Means switch off maschine- unplug Sid Board complete and exchange with another complite board.
Even one configured with 6581 other with 8580.
sorry for my terrible english..
regards
8
You could also connect both SID modules to the core at the same time. They will play exactly the same sound, but this doesn’t matter here. Just switch between the two Audio Outs. :slight_smile:
Hi there!
Just an bug report..
when I have the SID V1.6 alpha2 on the master core and select the SID 2-4 (also PIC18f) and I want to change  sound from the bankstick, It´s goes very slowly (huge latency)and the value jumps from 1 to 10 steps at the time…
But when I select the SID 1 (master) It´s behave perfect. ???
It´s works Ok with the V1.5c on the master and the V1.6 on the slaves..
Cheers
Christoffer
Hi Christoffer,
you are right. I’ve already fixed this imperfection, but haven’t made a new release due to the effort…
So, here the required changes:
open cs_menu_ms.inc, search for the CS_MENU_MS_Send_SysExDump function and the “bsf CS_STAT, CS_STAT_DISPLAY_INIT_REQ” instruction.
Remove this line
thereafter open “cs_menu.inc”, search for the CS_MENU_PatchUpdate function and insert “bsf CS_STAT, CS_STAT_DISPLAY_INIT_REQ” at the end of this function (before the return instruction)
This will also fix the problem with the channel selection in the CFG menu
Thanks!
;D
I’ve created a new alpha3 release which includes this bugfix and which comes with a modification for custom LCD drivers.
Please update also to MIOS V1.6 (this is especially recommented for people who are using multiple SID slaves)
