Midibox sid midi controller
Hi there!
i have a keyboard with 8 sliders and 8 knobs, all midi cc assignable.  What do u believe would be the optimal parameters setup (16 of them only) to control my midibox sid? Im working with two sids in a stereo config.
What keyboard is it exactly?
Midiplus 49 Origin: dead cheap but very effective!
theres also a video on youchoobe (not mine!)
no help?
Ok
people no longer have the power when people no longer help each other
thanks anyway
Your intial question is somewhat blurry and hard to answer. Your MIDI Keyboard is not especially common and MIDI Bindings for managing your SID parameters is a bit up to you.
When you talk about “optimal” setup, it’s also related on how you play and features you use, i mean there is no specific answer to this.
You ask for a MIDI “optimal” binding and mention controls on your keyboard and a SID synth. Which SID synth is it ? MB-6582 / Sammich ?
Can you map CC standalone or need a computer driver? No need to be angry ,just try to provide more information and be more precise in your question =)
Bests,
Jerome
I was not angry at all, just trying to induce somebody to answer
As for “optimal setup” i would mean some basic controls over  any given, pre programmed sound.. i can program the sound on the sammich itself, but i maybe then want to play around with some of its parameters, as you would in any synth with a few knobs and sliders..
maybe there is no specific answer, but an opinion or two could help
the keyboard can assign cc’s, i dont need a pc to do it.
thanks!
if you own a sammich, maybe getting some inspiration from the MB-6582 interface might help you to map your controls into something efficient?
sammichSID is basically one SID engine and 6582 manage 4. have a look here :
Great suggestion, i will use it as a starting point.
thanks
