Midibox SID + LTC
i have a sid application running without Controle surface, would it be possible to update the application with an LTC Module? or do i need a with surface to change baudrate or something?
Unforunately my PC is broken and i dont have any midi out on my laptop..
Thanks
So while I cannot answer your main question, I thought I might mention that M-Audio sells a USB<->MIDI adapter that works well. I use it to control my Midibox SID. I’m sure other vendors sell that same. I’d definitely recommend picking one of these up; you never know when you might need some MIDI connections :slight_smile:
