i’ve 2 multimiter, analog and digital. i’ve try them on a cheap variable PSU from 3V to 12V, at 12V they both misure 17,1V, at 9V they both misure 13,2V..
First, measuring voltage of cheap variable PSU is not a good test. With no load, this will be much higher than it is rated. It will be at the rated voltage at the rated load, like 500mA or 1000mA.
Where are you measuring the 11.5?
The picture looks like one of your regulators is removable.
Is this the regulator for the SID? Which one, 7809 or 7812?
Try taking it out, and measure voltage going into pins 1 and 2.
This should be around 14v DC above ground. Measuring pins 2 and 3 of the 7809 in PSU should be 9v DC.
the cheap psu misuring was only to see if the two multimeter was equal.
since i’ve use Otpim. PSU schem, the ground of 9VDC stop at pin2 of 7809PSU, than SID 7812/7809 and others caps take ground from +5VDC like in J2 of SID PCB.
11.5 is at the 7812SID when +5VDC is connected at 7809PSU pin2 and with the ground like i’ve show first.
mhmhm..
i must connect the 2 ground together?
thankyou
..add:
ahahah.. i’m so stupid! if i connect the 9VDC ground with 5VDC ground i short the +5VDC because of the pin2 7809PSU connected to +5V itself! :-[
That should be it. the pic is requesting an upload. What bootloader are you running? To work with the current MIOS it will need to be 1.9.
Are you getting a bunch of square blocks on your LCD? (that should be the normal thing for a bootloader only PIC)
There are good instructions for updating the bootloader with the 1.9 MIOS. The basic sequence is update bootloader-> upload MIOS -> upload SID application
i want to check interconnection with the InterTest. but i’ve a quest:
when i send a Modulation input, the voltage on the SID change just for a little time, or go to 5V since i don’t make another input?
there is no other way to test interconnection cable informatio between Core and Sid? my Pc and Core are too far to push SEND Modulation button and test the Sid Pins
Solder a 1k resistor to an LED. First test this between 5v and ground. Then insert into SID’s IC socket between pin to test (like A0, D0, etc.) and ground. Then you can watch for the LED to light from your PC ;D
I believe the pin being tested will go high until a new modulation event, all the others will go low. You should also not have the SID in the socket when testing.
tnx very good, i don’t know why i haven’t think this before
the problem is that the led not light up when i send Modulation by MIDI-OX.
i’ve tested all connection and solder of Jpins interconncetion CORE-SID, and are all oK..
p.s. just the CS# work.. i think because in just connected to the PIC.
at 08 & SER IC2 IC3 i’ve 5,2V but i must connect ground to IC pic and not +5V of multimeter.. it’s right way? i’ve 5,2 in the others pins that are connect to SIDj2(from CORE) but i must connect +5V of multi to the pin.
how to test if 74hc595 are sane? i’ve 0V if i test it with +Red multi on ICpins A0-A4 D0-D7, and 5,2V if i test them with -Black multi..
