Midibox Sid Install Questions
Hello. Last summer I built a midibox sid, but I got stuck on the installation phase. After editing the setup_6581.asm file and running the make command I got quite a few hex files, yet none of them are called ‘project.hex’. It appears that I am suppose to use this file in MIOS Studio 2 but I do not know how to get it. If someone could point me in the right direction it would be much appreciated.
Also in terms of where I am at in completing this project, how much more do I have to do? If there is one I would like to know what the next step is.
If you have an older core you should find what you need in this zip - http://uCApps.de/mios/midibox_sid_v2_043.zip.
you might need to update your bootloader too?
I have already been using the midibox_sid_v2_043 folder. Also the PIC I bought from SmashTV already came with the bootloader and MIOS. On the IC it reads:
BSL V1.2B MIOS V1.9G
Do you still think I would need to change the bootloader?
That should be fine.. So choose a .hex file and use mios studio to upload. From the readme included in the zip file: Some precompiled setups are part of this package: o setup_6581.hex (MBSID stuffed with 6581) o setup_8580.hex (MBSID stuffed with 8580) o setup_tk.hex (TK’s Setup) o setup_mb6582.hex (MB-6582 Setup) o setup_tk2.hex (TK’s Setup for his MB-6582) o setup_sammich_sid.hex (Special setup for sammichSID) They don’t need renaming, they are the same as project.hex. If it still doesn’t work try to upload mios again from the ‘midi’ folder in this http://ucapps.de/mios/mios_v1_9g.zip file, then retry the sid firmware.
I see what you are saying. setup_6581.hex is what I need. I tried using it yesterday but received an error in MIOS studio that indicated the core was not recognized. I am working through the trouble shooting guide right now.
