Midibox SID help
HI!! I made a midibox sid synthesizer but i dont know what i must to do to make any noise from SID.
Plese help me ???
Maybe you can be more specific?  ???
Did you check the connections from core to sid and are your voltages correct?
Averything is ok.Voltages are good.I’ve burned to the PIC bootstrap loader and now what???
  1. Restart the core and within 2 seconds load MIOS.
  2. After that, load the sid application and you’re ready to go! :slight_smile:
This procedure is explained all over the forum and on the ucapps main site. :wink:
Serge sysex loader (very simple procedure): http://69.56.171.55/~midibox/forum/index.php?topic=3255.0
main site (the old way)): http://www.ucapps.de/mios_bootstrap.html
Ok.When i power up the core and sid module (without LCD) i get a message in MIDI-Ox at Input window SYSX: F0 00 00 7E 40 00 01 F7 and the same in output window  SYSX: F0 00 00 7E 40 00 01 F7 .
When i want to send MIOS to the PIC via MIDI all the time  I get this messages .I can’t upload mios system??? Whats wrong???
the bootstrap should send out a message when the core starts, so that seems to be working.
it will keep sending until it has completed the mios upload.
i do not use midiox, so i’m not sure why you see it also in the midi out.
that should not be happening.
maybe you should turn midi thru off. or there is something wrong with your midi connections.
if you are sure that everything is ok, then you should try serge’s syses loader, from OnAcid’s post.
it is simpler to use.
hi,
I found it very confusing at first so posted in the testing trouble shooting section of the forum
http://69.56.171.55/~midibox/forum/index.php?topic=3943.0
http://69.56.171.55/~midibox/forum/index.php?topic=3960.0
I used Serge’s sysex loader and found it a breeze to use, highly recommended…
                              Jorge…
