@ jojjelito: This ist how my housing looks. At the moment I’m having the sequencer right next to me so I can not measure the thickness of the frontpanel PCB. (aprox. 1mm)
These dimensions fit.
/Edit TK: this diagram is obsolete, see next page (6) for updated picture with new spacer sizes (5mm + 2x18mm)
Cool! Thanks! I need to slap a case with sides together. Otherwise, chances are that my cats will put their paws in there and do something nasty to the electronics. Otherwise it’s a cool idea to do it your way
@ all: You need a vector based graphics program to work with the files I provided. This is not a ready-to-order-file. It is a cool basis to do what you want to do.
So, as mentioned before you need Adobe Illustrator, Corel-Draw or a similar programm. If anybody knows a really good working freeware tool to handle SVG-Files, please be so kind and let us know.
PS: I just found out that there is a suitable freeware program to handle these files. It is calles “Inkscape” and you can use it on a Windows-PC or on a Mac. Here is the link to Inkscape: http://inkscape.org/
I’m always in a lack of time so I’m not able to provide a file for a closed case wich is ready to use at the moment. As soon as I have a few minutes left I will do that.
What I have here is the original SVG File wich I took as the basis to built my acrylpanels. Maybe this is helpful for any one of you. This SVG file was exported from KiKad, wich is the layout software I used to make the board.
This SVG file is in 1:1 scale and the measures are 100% exact. You can download this file here:
Was thinking about hex cutouts (Shruthi case style), but haven’t made up my mind. Somewhere on that forum there’s a case thread which has a bewildering array of cool case design variants. Maybe the Sammich is also using hex cutouts, I don’t have one so I haven’t looked that closely. I need to fire up Inkscape and draw some shrooms so I’ll see what flows out. I won’t draw a case this week though :hmm: There’s the tiny bit of the panel wiring and finishing the modular first.
While I’m waiting for my PCB’s to show up in the mail I’ve constructed the MBHP_CORE_LPC17 module and I noticed various jumpers available. Which ones are needed for this project? and J26 on the PCB from SmashTV doesn’t show up in the docs page. Thanks for a great looking project.
George
Scroll on down a bit on the LPC page:
“Since the LPCXPRESSO module doesn’t provide dedicated pins for the two Ethernet Socket LEDs, you have to solder them directly from the appr. on-board SMD LEDs to J26 of the core module with two wires”
Well, there is the open case as designed by our esteemed cd_reloaded. I just thought I would add sides to this case as I have cats around me which aren’t good to exposed electronics. I intend to add some strange figures to engrave and make the case in a non-standard plexi since any variant is order-it-yourself. I’m taking a short break due to crummy, personal circumstances.
