I never used an EXIT LED by myself… ![]()
Will be fixed in beta4 (release this evening).
Next bug, please.
Next bug, please.
Beta4 is available for download.
ChangeLog:
[tt]
o MBSEQ Parameters are controllable via NRPN messages from external MIDI devices now.
See also doc/mbseqv4_cc_implementation.txt
o these parameters can also be controlled via Internal Loopback (Bus1 Port).
o Loopbacked CC Parameters are print in text format when edited
o implemented MIDI Remote Keyboard function (note: MBSEQ_HW.V4 has been updated)
See also doc/mbseqv4_remote_functions.txt
o fixed various minor bugs
[/tt]
I never used an EXIT LED by myself… Wink
I wouldn’t either but all of my Buttons have an LED by default…
so why not use them… and I really like the buttons to glow… ![]()
Next bug, please.
-Well, now the EXIT LED does not work at all
EDIT: removed entry about EDIT LED (user error)
Finally,
i would like to ask for a TRANSPOSE LED in some future release. Shame on me!
It is the only LED one not in us on my entire Frontpanel … so just for the bling…
->super super low priority
Best regards Gridracer
Ok, EXIT LED is now active whenever the menu selection page is displayed - this makes more sense anyhow.
And for the bling I added a Morph/Mixer/Transpose LED function.
Will be available in beta5.
Ok i had a suggestion for a new content on the lenght dialog on the Lenght page. It is possible, to fill the empty Space in the Left Display behind the Button 4 labled with Loop 1
In order to use a Quick selection for Looppoints i would be nice when i had a few points more in the dialog
On Step 5 labeld with Looppoint 9 means when i push GP Button 5 it will be loop the Step 9 - 16 immediatly
Example:
On GP Button 7 Loop at 9 … that will be Loop the Steps 9 - 16
On GP Button 6 Loop at 17 … that will be Loop the Steps 17 - 24
On GP Button 7 Loop at 25 … that will be Loop the Steps 25 - 32
On GP Button 8 Loop at 33… that will be Loop the Steps 33 - 40
For me i think that´s ok for the most common Step Lenght at max 32 Steps that i use.
The Name can be Quick Loop Points or so ! There a 19 charakters left on this empty field!
I hope that would be possible …
Have a nice Day,
Marco
Are you using the loop points while editing a sequence?
In this case, Fx->Loop is the right function.
E.g. “Loop in Step View” automatically plays the steps which are displayed on screen.
The loop function can be activated under Fx-Loop, or with the shortcut “MENU+Scrub”
Or do you want to use different loop zones during a performance?
Then just wait for the “Sections” feature, which will work similar to the way how I realized it for MB-808 (see TODO List in the ChangeLog). For A/B/C/D it will be possible to define different step offsets and lengths.
And this should be done in the Length page - therefore I’m not happy with your suggestion to put new items into this page (items which have to be removed later)!
Alright still don’t understand properly setting the tracks to 64 steps,128 steps ect.
I think I found a bug with the “all” function. When I have some notes laid down and I have them set to a low velocity then I add some more notes which are by default much higher, then I use the all function to lower the velocity and it lowers every notes velocity on the track. So far so good. BUT… the note gates go away and when I try to turn up the velocity I only get it on one step and not “ALL” steps. I was making hit hat vel variations and turned down the velocity a little too much and it makes your tracks drop out without an easy way to turn them back up. I hope i am clearly explaining myself.
regards,
echo
Press MENU->EVENT (GP button #2), ensure that a configuration with 64, 128 or 256 steps partitioning is selected (as desired)
Press MENU->LENGTH (GP button #6), and either select the length with GP encoder 2/3, or use GP button 14, 15, 16 for quick selection
By pressing the “Step View” button you can verify, which step is currently played.
The layout of this view depends on the max. number of steps…
Thats due to a programming problem (we have to remember which gates were inactive before), but I will try to find a proper solution. I guess that MBSEQ V3 showed the same behaviour?
Thanks TK.
I was only using the length function and not the event page setting.
As far as the “all” problem, should I reload v3 to verify that this already was occurring?
I will scratch my brain but I am no programmer.
I will replace the 128 and 256 steps items by “—” in the length page if not supported by the selected partitioning.
(on a graphical screen, we would gray out the items ;))
/Edit: + a warning message will be displayed if 128 or 256 steps selected.
No, since the code is implemented in a different way meanwhile.
For MBSEQ V3 the available RAM was the limitation, for V4 such limitations are a bit more relaxed, so that such special cases can be covered. It’s just only a question of time (and code complexity) to program it properly so that it works under all conditions (e.g. I have to differentiate between “normal” and “drum” tracks…)
News: today I implemented a generic list browser - I really like the implementation, it allows to browse through directories (or other lists) very quickly by using the whole screen + GP buttons/encoders and/or Datawheel/SELECT button. Once the SysEx librarian is completely available, I will continue with MIDI file import and export.
Still having issues with track lengths. I would look into event page and see that 64 steps is what is enabled with 16 par layers and 8 trig layers. Then go to menu + length and change it to 64/64 and then go to my stepview page and still see the track only cycling thru 1-16 and not 1-64. Loop is at one. A Lot of tracks also go thru 18-22 steps one cycle then the normal 16 steps the next time. Like I.E its going 36 steps and never passing the 1-16 mark. what else am i missing?
To comment further on my last post. Right now I have a track that is 64/64 steps in length in 16T triplet time and looking at step view it is cycling 1-24. Is this normal and why? I have an external master clock coming from my tr-707 and slaving the MBSEQ. I know on my roland drum machine the old manual tells you if you have a triplet pattern you should set the loop to only 12 steps instead of 16 steps to get a “proper loop”. I always kept the roland on 16 steps in triplet time. and put the clap on 5 and 13 like the beastie boys tell me to do so ;) Still confused here.
Could you please store the pattern which doesn’t play the steps correctly into 1:A1, and thereafter send me following files in a .zip package: MBSEQ_B1.V4, MBSEQ_C.V4 and MBSEQ_G.V4
Before sending, please check if the issue can be reproduced after power-on when pattern 1:A1 is selected again.
I will try to get this done tonight. At work right now 8)
As a side note. When I power the seq on the pattern in 1:A1 is the default “c-3 every 4 steps”. I have to hit the pattern button to select what I had assigned to 1:A1 last. Just thought I’d mention this. Going off memory I am sure the default “c-3 every 4 steps” pattern at boot will play patterns normally but I will find out later tonight.
Thanks again for taking so much time with this. By now I’m hoping its not human error so I won’t get whacked with the stupid stick!
And back to the fx echo reapeats not working correctly I have not been able to reproduce the lag I was previously talking about. It was probably my usb driver and lag on the pc or something as far as I can tell.
I checked track length 64 at my box, here etherything OK, 64 steps playing with divider 16 or 16T.
I also checked other track lengths.
But I have an Issue with the chaselight on the LED MATRIX when the length of one Track is longer than16:
When the selected Track is the one with more than 16 steps the chaselights of the other three Tracks
freeze when the Chaselight of the selected (> 16steps) Track reaches step 17, and they stay frozen untill the chaselight of the selected (> 16steps) Track reaches step 1 again.
When the selected Track is one with Steplength < or = 16 everything is OK.
This is reproduceable.
EDIT:
here is a link to a videoclip showing this Bug:
http://www.flickr.com/photos/gridracer/4011133399/
(Track 1=Length8, Track 2=Length32, Track 3&4=Length16)
Best Regards Gridracer
I’ve included some really useful reporting functions into beta5 which will help to find out the root cause.
More in the next mail.
If you send me the System, Globals, Tracks and TrackInfo report (TrackInfo only for the track which isn’t stepped correctly), I probably don’t need the files.
Thats the intended behaviour. Patterns are not automatically loaded after startup - we always start with the default setup like known from Canon Cameras. ![]()
The possible USB data rate which can be handled by STM32 is pretty high. It could happen that your host application causes the problem if it receives so many events.
E.g., I’ve a similar issue with MIOS Studio under MacOS when a lot of debugging messages are received. It can take minutes until MIOS Studio displayed everything what MIOS32 has sent within one second.
No issue with host applications like Logic Studio… they can handle the data rate without failures.
Ok, will be checked, but this can take a bit longer, since I have to open my MBSEQ V3 case to test the BLM with V4 firmware. Maybe a code review helps to find the root cause earlier…
Beta5 is available, ChangeLog:
[tt]
o overworked menu page selection (now uses new list browser)
o added new info page “About this MIDIbox” (at the end of menu list) to
simplify support.
A lot of additional informations are sent to the MIOS Terminal when
an item (displayed at left page) is selected with a GP or the SELECT
button. Use the datawheel or a GP encoder to browse through the list.
MIOS Terminal is part of MIOS Studio, a command line tool for MacOS
available as well.
o Length 128/256 quick selection won’t be displayed anymore if track
partition doesn’t allow this number of steps
[/tt]
Here some tips how you can help me to understand/reproduce your reported issues in future by using the new debugging functions.
Here an example of the System Report:
00000000295358 ms | System Informations:
00000000295359 ms | ====================
00000000295359 ms | MIDIbox SEQ V4.0Beta5 (C) 2009 T. Klose
00000000295359 ms | Operating System: MIOS32
00000000295359 ms | Board: MBHP_CORE_STM32
00000000295359 ms | Chip Family: STM32F10x
00000000295359 ms | Serial Number: 35FFFFFF5836393633322443
00000000295360 ms | Flash Memory Size: 524288 bytes
00000000295360 ms | RAM Size: 65536 bytes
00000000295360 ms | Systime: 00:20:13
00000000295360 ms | CPU Load: 58%
00000000295361 ms | MIDI Scheduler: Alloc 0/ 16 Drops: 0
00000000295361 ms | Stopwatch: 54/651 uS
[/code]
SD Card Report:
[code]
00000000005596 ms | SD Card Informations
00000000005596 ms | ====================
00000000005596 ms | --------------------
00000000005596 ms | CID:
00000000005596 ms | - ManufacturerID:
00000000005596 ms | - OEM AppliID:
00000000005596 ms | - ProdName: SD01G
00000000005596 ms | - ProdRev: 128
00000000005596 ms | - ProdSN: 0x6067a202
00000000005596 ms | - Reserved1: 0
00000000005596 ms | - ManufactDate: 123
00000000005596 ms | - msd\_CRC: 0x0d
00000000005596 ms | - Reserved2: 1
00000000005596 ms | - CSDStruct: 0
00000000005596 ms | - SysSpecVersion: 0
00000000005596 ms | - TAAC: 38
00000000005596 ms | - NSAC: 0
00000000005596 ms | - MaxBusClkFrec: 50
00000000005598 ms | - CardComdClasses: 1525
00000000005598 ms | - RdBlockLen: 9
00000000005598 ms | - PartBlockRead: 1
00000000005598 ms | - WrBlockMisalign: 0
00000000005598 ms | - RdBlockMisalign: 0
00000000005598 ms | - DSRImpl: 0
00000000005598 ms | - Reserved2: 0
00000000005598 ms | - DeviceSize: 3874
00000000005598 ms | - MaxRdCurrentVDDMin: 7
00000000005598 ms | - MaxRdCurrentVDDMax: 6
00000000005598 ms | - MaxWrCurrentVDDMin: 7
00000000005599 ms | - MaxWrCurrentVDDMax: 6
00000000005599 ms | - DeviceSizeMul: 7
00000000005599 ms | - EraseGrSize: 19
00000000005599 ms | - EraseGrMul: 31
00000000005599 ms | - WrProtectGrSize: 31
00000000005599 ms | - WrProtectGrEnable: 1
00000000005600 ms | - ManDeflECC: 0
00000000005600 ms | - WrSpeedFact: 4
00000000005600 ms | - MaxWrBlockLen: 9
00000000005600 ms | - WriteBlockPaPartial: 0
00000000005600 ms | - Reserved3: 0
00000000005600 ms | - ContentProtectAppli: 0
00000000005600 ms | - FileFormatGrouop: 0
00000000005600 ms | - CopyFlag: 1
00000000005600 ms | - PermWrProtect: 0
00000000005600 ms | - TempWrProtect: 0
00000000005600 ms | - FileFormat: 0
00000000005600 ms | - ECC: 0
00000000005600 ms | - msd\_CRC: 0x6b
00000000005600 ms | - Reserved4: 1
00000000005600 ms | --------------------
00000000005603 ms | --------------------
00000000005603 ms | Partition 0 start sector 63 active 0x00 type 0x0b size 1983933
00000000005603 ms | Volume label 'MBSEQ TK '
00000000005603 ms | 8 sector/s per cluster, 32 reserved sector/s, volume total 1983933 sectors.
00000000005603 ms | 1934 sectors per FAT, first FAT at sector #95, root dir at #2.
00000000005603 ms | (For FAT32, the root dir is a CLUSTER number, FAT12/16 it is a SECTOR number)
00000000005604 ms | 0 root dir entries, data area commences at sector #3963.
00000000005604 ms | 247496 clusters (1013743616 bytes) in data area, filesystem IDd as FAT32
00000000005606 ms | Content of root directory:
00000000005606 ms | - MBSEQ
00000000005606 ms | - \_~1.TRA
00000000005606 ms | - MBSEQ\_B1
00000000005606 ms | - TRASHE~1
00000000005606 ms | - MBSEQ\_C
00000000005606 ms | - SPOTLI~1
00000000005606 ms | - MBSEQ\_B2
00000000005606 ms | - MBSEQ\_B3
00000000005606 ms | - MBSEQ\_B4
00000000005606 ms | - MBSEQ\_B5
00000000005606 ms | - MBSEQ\_B6
00000000005607 ms | - MBSEQ\_B7
00000000005607 ms | - MBSEQ\_B8
00000000005608 ms | - MBSEQ\_G
00000000005608 ms | - MBSEQ\_HW
00000000005608 ms | - MBSEQ\_M
00000000005608 ms | - MBSEQ\_S
00000000005608 ms | - SYSEX
00000000005608 ms | - SYSEX2
00000000005617 ms | Found 19 directory entries.
00000000005617 ms | --------------------
00000000005617 ms |
00000000005617 ms | Checking SD Card at application layer
00000000005617 ms | =====================================
00000000005617 ms | Deriving SD Card informations - please wait!
00000000009489 ms | SD Card: 'MBSEQ TK ': 1008 of 1013 MB free
00000000009489 ms | File MBSEQ\_B1.V4: valid (64 patterns)
00000000009489 ms | File MBSEQ\_B2.V4: valid (64 patterns)
00000000009489 ms | File MBSEQ\_B3.V4: valid (64 patterns)
00000000009490 ms | File MBSEQ\_B4.V4: valid (64 patterns)
00000000009490 ms | File MBSEQ\_B5.V4: valid (64 patterns)
00000000009490 ms | File MBSEQ\_B6.V4: valid (64 patterns)
00000000009490 ms | File MBSEQ\_B7.V4: valid (64 patterns)
00000000009490 ms | File MBSEQ\_B8.V4: valid (64 patterns)
00000000009490 ms | File MBSEQ\_M.V4: valid (64 mixer maps)
00000000009490 ms | File MBSEQ\_S.V4: valid (64 songs)
00000000009490 ms | File MBSEQ\_G.V4: valid
00000000009492 ms | File MBSEQ\_C.V4: valid
00000000009492 ms | File MBSEQ\_HW.V4: valid
00000000009492 ms | done.
A Track Report:
00000000336346 ms | Track Overview:
00000000336346 ms | ===============
00000000336346 ms | | Track | Mode | Layer P/T/I | Steps P/T | Length | Port | Chn. | Muted |
00000000336346 ms | +-------+-------+-------------+-----------+--------+-------+------+-------+
00000000336346 ms | | G1T1 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 9 | no |
00000000336346 ms | | G1T2 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 9 | no |
00000000336348 ms | | G1T3 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 12 | no |
00000000336349 ms | | G1T4 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 12 | no |
00000000336349 ms | | G2T1 | Drum | 1/ 2/16 | 64/ 64 | 32 | Def. | 10 | no |
00000000336349 ms | | G2T2 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 10 | no |
00000000336350 ms | | G2T3 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 10 | no |
00000000336351 ms | | G2T4 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 10 | no |
00000000336351 ms | | G3T1 | Note | 4/ 8/ 1 | 256/256 | 16 | Def. | 11 | no |
00000000336351 ms | | G3T2 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 10 | no |
00000000336351 ms | | G3T3 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 11 | no |
00000000336351 ms | | G3T4 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 12 | no |
00000000336353 ms | | G4T1 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 13 | no |
00000000336354 ms | | G4T2 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 14 | no |
00000000336354 ms | | G4T3 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 15 | no |
00000000336354 ms | | G4T4 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 16 | no |
00000000336354 ms | +-------+-------+-------------+-----------+--------+-------+------+-------+
00000000336354 ms | done.
[/code]
A Track Info Report:
[code]
00000000092685 ms | Track Parameters of G1T1
00000000092686 ms | ========================
00000000092686 ms | Name: ' '
00000000092686 ms | Track Mode: 1 (Normal)
00000000092686 ms | Track Mode Flags: 3 (Unsorted: on, Hold: on, Restart: off, Force Scale: off, Sustain: off)
00000000092686 ms | Event Mode: 0 (Note )
00000000092686 ms | MIDI Port: 0x00 (Def. )
00000000092686 ms | MIDI Channel: 8 (#9)
00000000092686 ms | Direction Mode: 0 (Forward)
00000000092686 ms | Steps Forward: 0 (1 Steps)
00000000092686 ms | Steps Jump Back: 0 (0 Steps)
00000000092686 ms | Steps Replay: 0
00000000092686 ms | Steps Repeat: 0 (0 times)
00000000092686 ms | Steps Skip: 0 (0 Steps)
00000000092687 ms | Steps Repeat/Skip Interval: 3 (4 Steps)
00000000092687 ms | Clockdivider: 15 (16/384 ppqn)
00000000092687 ms | Triplets: no
00000000092688 ms | Synch-To-Measure: no
00000000092688 ms | Length: 15 (16 Steps)
00000000092688 ms | Loop: 0 (Step 1)
00000000092688 ms | Transpose Semitones: 0 (+0)
00000000092688 ms | Transpose Octaves: 0 (+0)
00000000092688 ms | Morph Mode: 0 (off)
00000000092688 ms | Morph Destination Range: 0 (1..16)
00000000092689 ms | Humanize Mode: 0 (Note: off, Velocity: off, Length: off)
00000000092689 ms | Humanize Intensity: 0
00000000092689 ms | Groove Style: 0
00000000092689 ms | Groove Intensity: 0
00000000092689 ms | Trigger Assignment Gate: 1 (A)
00000000092689 ms | Trigger Assignment Accent: 2 (B)
00000000092689 ms | Trigger Assignment Roll: 3 (C)
00000000092690 ms | Trigger Assignment Glide: 4 (D)
00000000092690 ms | Trigger Assignment Skip: 5 (E)
00000000092691 ms | Trigger Assignment Random Gate: 6 (F)
00000000092691 ms | Trigger Assignment Random Value: 7 (G)
00000000092691 ms | Trigger Assignment No Fx: 8 (H)
00000000092691 ms | Drum Parameter Assignment A: 0 (None )
00000000092691 ms | Drum Parameter Assignment B: 0 (None )
00000000092691 ms | Echo Repeats: 0
00000000092691 ms | Echo Delay: 5 ( 16 )
00000000092691 ms | Echo Velocity: 15
00000000092691 ms | Echo Feedback Velocity: 15 (75%)
00000000092691 ms | Echo Feedback Note: 24 (+0)
00000000092691 ms | Echo Feedback Gatelength: 20 (100%)
00000000092691 ms | Echo Feedback Ticks: 20 (100%)
00000000092691 ms | LFO Waveform: 0 ( off )
00000000092691 ms | LFO Amplitude: 192 (64)
00000000092693 ms | LFO Phase: 0 (0%)
00000000092693 ms | LFO Interval: 15 (16 Steps)
00000000092693 ms | LFO Reset Interval: 15 (16 Steps)
00000000092693 ms | LFO Flags: 0 (Oneshot: off, Note: off, Velocity: off, Length: off, CC: off)
00000000092693 ms | LFO Extra CC: 0
00000000092693 ms | LFO Extra CC Offset: 64
00000000092693 ms | LFO Extra CC PPQN: 96
00000000092693 ms | Note Limit Lower: 0
00000000092693 ms | Note Limit Upper: 0
00000000092693 ms | Parameter Layer Assignments:
00000000092694 ms | 00000000 01 03 04 09 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000000092695 ms | CC Assignments:
00000000092695 ms | 00000000 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E 1F ................
00000000092695 ms | Constant Array C:
00000000092695 ms | 00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000000092695 ms | done.
A mixer map:
00000000114314 ms | Mixer Map # 1
00000000114315 ms | ==============
00000000114315 ms | |Num|Port|Chn|Prg|Vol|Pan|Rev|Cho|Mod|CC1|CC2|CC3|CC4|C1A|C2A|C3A|C4A|
00000000114315 ms | +---+----+---+---+---+---+---+---+---+---+---+---+---+---+---+---+---+
00000000114315 ms | | 0|Def.| 1| - | - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114316 ms | | 1|Def.| 2| - | - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114316 ms | | 2|Def.| 3| - | - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114317 ms | | 3|Def.| 4| - | - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114326 ms | | 4|Def.| 5| 54| - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114326 ms | | 5|Def.| 6| - | - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114326 ms | | 6|Def.| 7| - | - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114326 ms | | 7|Def.| 8| 33| - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114326 ms | | 8|Def.| 9| 38| - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114326 ms | | 9|Def.| 10| - | - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114326 ms | | 10|Def.| 11| - | - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114326 ms | | 11|Def.| 12| - | - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114326 ms | | 12|Def.| 13| 3| - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114326 ms | | 13|Def.| 14| - | - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114326 ms | | 14|Def.| 15| - | - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114326 ms | | 15|Def.| 16| - | - | - | - | - | - | - | - | - | - | 16| 17| 18| 19|
00000000114326 ms | +---+----+---+---+---+---+---+---+---+---+---+---+---+---+---+---+---+
00000000114326 ms | done.
[/code]
Note that such reports could also help you to analyse an issue.
However, there is no support from my side for more detailed informations on the values which are displayed, especially for these hex dumps:
[code]
00000000472020 ms | Song # 1
00000000472020 ms | ========
00000000472020 ms | Name: ' '
00000000472020 ms | 00000000 00 00 80 80 80 80 10 32 11 08 0A 80 80 80 10 32 .......2.......2
00000000472021 ms | 00000010 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472021 ms | 00000020 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472021 ms | 00000030 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472022 ms | 00000040 04 00 11 11 11 10 54 76 11 10 80 80 80 80 10 32 ......Tv.......2
00000000472023 ms | 00000050 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472023 ms | 00000060 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472024 ms | 00000070 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472024 ms | 00000080 04 00 11 11 12 10 54 76 11 18 80 80 80 80 10 32 ......Tv.......2
00000000472024 ms | 00000090 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472024 ms | 000000A0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472025 ms | 000000B0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472025 ms | 000000C0 04 00 11 13 15 10 54 76 11 18 80 80 80 80 10 32 ......Tv.......2
00000000472026 ms | 000000D0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472027 ms | 000000E0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472027 ms | 000000F0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472030 ms | 00000100 01 00 08 08 08 09 54 76 00 00 80 80 80 80 10 32 ......Tv.......2
00000000472030 ms | 00000110 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472030 ms | 00000120 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472030 ms | 00000130 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472030 ms | 00000140 01 00 0B 09 09 08 54 76 00 00 80 80 80 80 10 32 ......Tv.......2
00000000472030 ms | 00000150 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472030 ms | 00000160 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472030 ms | 00000170 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472032 ms | 00000180 01 00 09 0A 09 09 54 76 00 00 80 80 80 80 10 32 ......Tv.......2
00000000472032 ms | 00000190 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472032 ms | 000001A0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472032 ms | 000001B0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472032 ms | 000001C0 01 00 0A 0A 09 09 54 76 00 00 80 80 80 80 10 32 ......Tv.......2
00000000472032 ms | 000001D0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472036 ms | 000001E0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472036 ms | 000001F0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472036 ms | 00000200 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472036 ms | 00000210 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472036 ms | 00000220 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472036 ms | 00000230 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472036 ms | 00000240 01 00 00 00 01 01 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472036 ms | 00000250 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472036 ms | 00000260 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472037 ms | 00000270 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472038 ms | 00000280 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472038 ms | 00000290 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472038 ms | 000002A0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472040 ms | 000002B0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472040 ms | 000002C0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472040 ms | 000002D0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472040 ms | 000002E0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472041 ms | 000002F0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472041 ms | 00000300 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472041 ms | 00000310 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472042 ms | 00000320 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472042 ms | 00000330 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472043 ms | 00000340 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472043 ms | 00000350 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472045 ms | 00000360 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472045 ms | 00000370 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472045 ms | 00000380 13 01 80 80 80 80 10 32 01 00 08 0A 08 0B 10 32 .......2.......2
00000000472045 ms | 00000390 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472051 ms | 000003A0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472051 ms | 000003B0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472051 ms | 000003C0 13 00 80 80 80 80 10 32 01 00 0A 0A 09 0A 10 32 .......2.......2
00000000472051 ms | 000003D0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472051 ms | 000003E0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472051 ms | 000003F0 00 00 80 80 80 80 10 32 00 00 80 80 80 80 10 32 .......2.......2
00000000472051 ms | done.
Beta6 is available; ChangeLog:
[tt]
o now it’s possible to send SysEx dumps stored on SD Card to MIDI devices.
Preparation: create a directory called “sysex” on your SD Card, thereafter
create subdirectories for each MIDI Device you want to use.
For example:
sysex/MBSID
sysex/MBFM
sysex/MicroQ
Now copy .syx files into these directories which should be sent to the
devices later.
Thats all! On your MIDIbox SEQ, change to the MENU->SYSEX menu, the
devices will be displayed on screen. Select a device to browse through
the file list. Select a file to send the dump.
Note: currently .syx files are only sent to the Default port (selected in
MIDI page). A “store .syx dump” function is planned for later releases.
o Menu page shows the current sequencer position in measure.step.microstep
format
o “About this MIDIbox”: separated SD Card Info
[/tt]
Ok I hope I am doing this right. I included only two trackinfos. Hopefully this will help show me what I am doing wrong.
00000000050397 ms |
00000000050397 ms | System Informations:
00000000050397 ms | ====================
00000000050397 ms | MIDIbox SEQ V4.0Beta6 (C) 2009 T. Klose
00000000050397 ms | Operating System: MIOS32
00000000050397 ms | Board: MBHP_CORE_STM32
00000000050397 ms | Chip Family: STM32F10x
00000000050397 ms | Serial Number: 35FFFFFF5836393644562543
00000000050397 ms | Flash Memory Size: 524288 bytes
00000000050398 ms | RAM Size: 65536 bytes
00000000050398 ms | Systime: 00:12:47
00000000050398 ms | CPU Load: 59%
00000000050398 ms | MIDI Scheduler: Alloc 0/ 29 Drops: 0
00000000050398 ms | Stopwatch: 54/1122 uS
00000000050398 ms | done.
00000000304375 ms |
00000000304375 ms | Global Settings:
00000000304375 ms | ================
00000000304375 ms | BPMx10_P 0 740 0
00000000304375 ms | BPMx10_P 1 800 0
00000000304375 ms | BPMx10_P 2 850 0
00000000304375 ms | BPMx10_P 3 740 0
00000000304375 ms | BPMx10_P 4 950 0
00000000304375 ms | BPMx10_P 5 1000 0
00000000304375 ms | BPMx10_P 6 1050 0
00000000304375 ms | BPMx10_P 7 1100 0
00000000304375 ms | BPMx10_P 8 1150 0
00000000304375 ms | BPMx10_P 9 1200 0
00000000304377 ms | BPMx10_P 10 1250 0
00000000304377 ms | BPMx10_P 11 1300 0
00000000304377 ms | BPMx10_P 12 1350 0
00000000304377 ms | BPMx10_P 13 981 0
00000000304377 ms | BPMx10_P 14 1450 0
00000000304377 ms | BPMx10_P 15 1500 0
00000000304377 ms | BPM_Preset 0
00000000304377 ms | BPM_Mode 0
00000000304377 ms | BPM_DINSyncDiv 384
00000000304377 ms | SynchedPatternChange 0
00000000304377 ms | StepsPerMeasure 15
00000000304377 ms | GlobalScale 0
00000000304377 ms | GlobalScaleCtrl 0
00000000304377 ms | GlobalScaleRoot 0
00000000304377 ms | LoopMode 1
00000000304377 ms | LoopOffset 1
00000000304379 ms | LoopSteps 32
00000000304379 ms | MIDI_DefaultPort 16
00000000304379 ms | MIDI_IN_Channel 1
00000000304379 ms | MIDI_IN_Port 0
00000000304379 ms | MIDI_IN_MClock_Ports 0x000f0f01
00000000304379 ms | MIDI_IN_TA_Split 0
00000000304379 ms | MIDI_IN_TA_SplitNote 60
00000000304379 ms | MIDI_OUT_MClock_Ports 0x7fffffff
00000000304379 ms | MIDI_RouterNode 0 32 0 32 0
00000000304379 ms | MIDI_RouterNode 1 0 0 32 0
00000000304381 ms | MIDI_RouterNode 2 0 0 32 0
00000000304381 ms | MIDI_RouterNode 3 0 0 32 0
00000000304381 ms | MIDI_RouterNode 4 0 0 32 0
00000000304381 ms | MIDI_RouterNode 5 0 0 32 0
00000000304381 ms | MIDI_RouterNode 6 0 0 32 0
00000000304381 ms | MIDI_RouterNode 7 0 0 32 0
00000000304381 ms | MetronomePort 0
00000000304381 ms | MetronomeChannel 10
00000000304381 ms | MetronomeNoteM 37
00000000304381 ms | MetronomeNoteB 37
00000000304381 ms | RemoteMode 0
00000000304381 ms | RemotePort 0
00000000304381 ms | RemoteID 0
00000000304381 ms | done.
00000000387517 ms |
00000000387517 ms | Track Overview:
00000000387517 ms | ===============
00000000387517 ms | | Track | Mode | Layer P/T/I | Steps P/T | Length | Port | Chn. | Muted |
00000000387517 ms | +-------+-------+-------------+-----------+--------+-------+------+-------+
00000000387518 ms | | G1T1 | Note | 16/ 8/ 1 | 64/ 64 | 64 | Def. | 5 | no |
00000000387518 ms | | G1T2 | Note | 16/ 8/ 1 | 64/ 64 | 32 | Def. | 6 | no |
00000000387520 ms | | G1T3 | Note | 16/ 8/ 1 | 64/ 64 | 32 | Def. | 7 | no |
00000000387520 ms | | G1T4 | Note | 16/ 8/ 1 | 64/ 64 | 64 | Def. | 8 | no |
00000000387520 ms | | G2T1 | Note | 16/ 8/ 1 | 64/ 64 | 64 | Def. | 5 | yes |
00000000387520 ms | | G2T2 | Note | 16/ 8/ 1 | 64/ 64 | 32 | Def. | 6 | yes |
00000000387520 ms | | G2T3 | Note | 16/ 8/ 1 | 64/ 64 | 32 | Def. | 7 | yes |
00000000387522 ms | | G2T4 | Note | 16/ 8/ 1 | 64/ 64 | 32 | Def. | 8 | yes |
00000000387522 ms | | G3T1 | Note | 16/ 8/ 1 | 64/ 64 | 32 | Def. | 9 | no |
00000000387522 ms | | G3T2 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 10 | no |
00000000387524 ms | | G3T3 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 11 | no |
00000000387524 ms | | G3T4 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 12 | no |
00000000387524 ms | | G4T1 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 13 | no |
00000000387524 ms | | G4T2 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 14 | no |
00000000387524 ms | | G4T3 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 15 | no |
00000000387526 ms | | G4T4 | Note | 16/ 8/ 1 | 64/ 64 | 16 | Def. | 16 | no |
00000000387526 ms | +-------+-------+-------------+-----------+--------+-------+------+-------+
00000000387526 ms | done.
00000000481245 ms |
00000000481245 ms | Track Parameters of G1T1
00000000481245 ms | ========================
00000000481245 ms | Name: ' '
00000000481245 ms | Track Mode: 1 (Normal)
00000000481245 ms | Track Mode Flags: 3 (Unsorted: on, Hold: on, Restart: off, Force Scale: off, Sustain: off)
00000000481246 ms | Event Mode: 0 (Note )
00000000481246 ms | MIDI Port: 0x00 (Def. )
00000000481246 ms | MIDI Channel: 4 (#5)
00000000481246 ms | Direction Mode: 0 (Forward)
00000000481246 ms | Steps Forward: 0 (1 Steps)
00000000481246 ms | Steps Jump Back: 0 (0 Steps)
00000000481247 ms | Steps Replay: 0
00000000481247 ms | Steps Repeat: 0 (0 times)
00000000481247 ms | Steps Skip: 0 (0 Steps)
00000000481247 ms | Steps Repeat/Skip Interval: 3 (4 Steps)
00000000481247 ms | Clockdivider: 15 (16/384 ppqn)
00000000481247 ms | Triplets: no
00000000481247 ms | Synch-To-Measure: yes
00000000481247 ms | Length: 63 (64 Steps)
00000000481247 ms | Loop: 0 (Step 1)
00000000481248 ms | Transpose Semitones: 0 (+0)
00000000481248 ms | Transpose Octaves: 0 (+0)
00000000481248 ms | Morph Mode: 0 (off)
00000000481248 ms | Morph Destination Range: 0 (1..64)
00000000481249 ms | Humanize Mode: 0 (Note: off, Velocity: off, Length: off)
00000000481249 ms | Humanize Intensity: 0
00000000481249 ms | Groove Style: 0
00000000481249 ms | Groove Intensity: 0
00000000481249 ms | Trigger Assignment Gate: 1 (A)
00000000481249 ms | Trigger Assignment Accent: 2 (B)
00000000481249 ms | Trigger Assignment Roll: 3 (C)
00000000481249 ms | Trigger Assignment Glide: 4 (D)
00000000481250 ms | Trigger Assignment Skip: 5 (E)
00000000481250 ms | Trigger Assignment Random Gate: 6 (F)
00000000481250 ms | Trigger Assignment Random Value: 7 (G)
00000000481250 ms | Trigger Assignment No Fx: 8 (H)
00000000481251 ms | Drum Parameter Assignment A: 0 (None )
00000000481251 ms | Drum Parameter Assignment B: 0 (None )
00000000481251 ms | Echo Repeats: 0
00000000481251 ms | Echo Delay: 7 ( 8 )
00000000481251 ms | Echo Velocity: 15
00000000481251 ms | Echo Feedback Velocity: 15 (75%)
00000000481251 ms | Echo Feedback Note: 24 (+0)
00000000481251 ms | Echo Feedback Gatelength: 20 (100%)
00000000481252 ms | Echo Feedback Ticks: 20 (100%)
00000000481252 ms | LFO Waveform: 0 ( off )
00000000481252 ms | LFO Amplitude: 192 (64)
00000000481252 ms | LFO Phase: 0 (0%)
00000000481252 ms | LFO Interval: 15 (16 Steps)
00000000481253 ms | LFO Reset Interval: 15 (16 Steps)
00000000481253 ms | LFO Flags: 0 (Oneshot: off, Note: off, Velocity: off, Length: off, CC: off)
00000000481253 ms | LFO Extra CC: 0
00000000481253 ms | LFO Extra CC Offset: 64
00000000481253 ms | LFO Extra CC PPQN: 96
00000000481253 ms | Note Limit Lower: 0
00000000481254 ms | Note Limit Upper: 0
00000000481254 ms | Parameter Layer Assignments:
00000000481254 ms | 00000000 01 03 04 09 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000000481254 ms | CC Assignments:
00000000481255 ms | 00000000 01 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E ................
00000000481255 ms | Constant Array C:
00000000481255 ms | 00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000000481255 ms | done.
00000000543055 ms |
00000000543055 ms | Track Parameters of G1T2
00000000543055 ms | ========================
00000000543055 ms | Name: ' '
00000000543055 ms | Track Mode: 1 (Normal)
00000000543056 ms | Track Mode Flags: 3 (Unsorted: on, Hold: on, Restart: off, Force Scale: off, Sustain: off)
00000000543056 ms | Event Mode: 0 (Note )
00000000543056 ms | MIDI Port: 0x00 (Def. )
00000000543056 ms | MIDI Channel: 5 (#6)
00000000543056 ms | Direction Mode: 0 (Forward)
00000000543057 ms | Steps Forward: 0 (1 Steps)
00000000543057 ms | Steps Jump Back: 0 (0 Steps)
00000000543057 ms | Steps Replay: 0
00000000543057 ms | Steps Repeat: 0 (0 times)
00000000543057 ms | Steps Skip: 0 (0 Steps)
00000000543057 ms | Steps Repeat/Skip Interval: 3 (4 Steps)
00000000543058 ms | Clockdivider: 15 (16/384 ppqn)
00000000543058 ms | Triplets: no
00000000543058 ms | Synch-To-Measure: yes
00000000543058 ms | Length: 31 (32 Steps)
00000000543058 ms | Loop: 0 (Step 1)
00000000543058 ms | Transpose Semitones: 0 (+0)
00000000543058 ms | Transpose Octaves: 0 (+0)
00000000543059 ms | Morph Mode: 0 (off)
00000000543059 ms | Morph Destination Range: 0 (1..32)
00000000543059 ms | Humanize Mode: 0 (Note: off, Velocity: off, Length: off)
00000000543059 ms | Humanize Intensity: 0
00000000543059 ms | Groove Style: 0
00000000543059 ms | Groove Intensity: 0
00000000543060 ms | Trigger Assignment Gate: 1 (A)
00000000543060 ms | Trigger Assignment Accent: 2 (B)
00000000543060 ms | Trigger Assignment Roll: 3 (C)
00000000543060 ms | Trigger Assignment Glide: 4 (D)
00000000543060 ms | Trigger Assignment Skip: 5 (E)
00000000543061 ms | Trigger Assignment Random Gate: 6 (F)
00000000543061 ms | Trigger Assignment Random Value: 7 (G)
00000000543061 ms | Trigger Assignment No Fx: 8 (H)
00000000543061 ms | Drum Parameter Assignment A: 0 (None )
00000000543061 ms | Drum Parameter Assignment B: 0 (None )
00000000543061 ms | Echo Repeats: 0
00000000543062 ms | Echo Delay: 7 ( 8 )
00000000543062 ms | Echo Velocity: 15
00000000543062 ms | Echo Feedback Velocity: 15 (75%)
00000000543062 ms | Echo Feedback Note: 24 (+0)
00000000543062 ms | Echo Feedback Gatelength: 20 (100%)
00000000543062 ms | Echo Feedback Ticks: 20 (100%)
00000000543062 ms | LFO Waveform: 0 ( off )
00000000543063 ms | LFO Amplitude: 192 (64)
00000000543063 ms | LFO Phase: 0 (0%)
00000000543063 ms | LFO Interval: 15 (16 Steps)
00000000543063 ms | LFO Reset Interval: 15 (16 Steps)
00000000543063 ms | LFO Flags: 0 (Oneshot: off, Note: off, Velocity: off, Length: off, CC: off)
00000000543064 ms | LFO Extra CC: 0
00000000543064 ms | LFO Extra CC Offset: 64
00000000543064 ms | LFO Extra CC PPQN: 96
00000000543064 ms | Note Limit Lower: 0
00000000543064 ms | Note Limit Upper: 0
00000000543064 ms | Parameter Layer Assignments:
00000000543064 ms | 00000000 01 03 04 09 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000000543064 ms | CC Assignments:
00000000543066 ms | 00000000 01 10 11 12 13 14 15 16 17 18 19 1A 1B 1C 1D 1E ................
00000000543066 ms | Constant Array C:
00000000543066 ms | 00000000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00000000543066 ms | done.
Ha figured it out!
Options page right under the word change it was set to 16 and I set that to 256. Why would someone set this to 16? When looking at the code under global settings it is the steps per measure correct?
Also what does sync pat change (on/off) do exactly? (in options)
Regards,
Echo
