Just think about it: do you think that I would ever throw away my existing MIDIbox SEQ frontpanel?
Apparently, it’s an optional feature, and I for myself will built this into a seperate 19" rack case.
The sequencer works nice without the Button/Duo-LED matrix - it’s just one of many features
The schematic is a mix of the button and historic single-colour LED matrix, I will publish it once I find the time to draw the connections.
Here some additional infos from the ChangeLog:
[tt]
o overworked LED matrix, implemented button matrix
There are several configurations possible, here the tested ones:
a) historic 4x16 LED matrix which replaces the 1x16 GP LED row
Required settings in main.asm (or alternatively setup_*.asm) - search for the values and change the numbers:
#define DEFAULT_SRM_ENABLED 1 ; enable the LED matrix
#define DEFAULT_SRM_DOUT_L1 3 ; DOUT register of the left side (8 LEDs)
#define DEFAULT_SRM_DOUT_R1 4 ; DOUT register of the right side (8 LEDs)
#define DEFAULT_SRM_DOUT_CATHODES1 5 ; DOUT register which controls the LED cathodes - 4 pins used
#define DEFAULT_SRM_DOUT_CATHODES1 6 ; can be optionally selected if LEDs with high power consumption are used
#define DEFAULT_SRM_DOUT_DUOCOLOUR 0 ; no DUO colour LEDs
#define DEFAULT_SRM_DOUT_L2 0 ; only relevant for DUO colour LEDs
#define DEFAULT_SRM_DOUT_R2 0 ; only relevant for DUO colour LEDs
#define DEFAULT_SRM_BUTTONS_ENABLED 0 ; no button matrix
#define DEFAULT_SRM_BUTTONS_NO_UI 0 ; only relevant for button matrix
#define DEFAULT_SRM_DIN_L 0 ; only relevant for button matrix
#define DEFAULT_SRM_DIN_R 0 ; only relevant for button matrix
Note: compared to the old schematic, the cathodes are now mirrored!
This means that you have to change the wiring on your existing hardware
Upper Row: DOUT pin D7
second Row: DOUT pin D6
third Row: DOUT pin D5
fourth Row: DOUT pin D4
b) 16 “GP LEDs” + 4x16 seperate LED matrix
recommented solution, since this allows the firmware to display menu parameters seperately below the LCDs
#define DEFAULT_SRM_DOUT_L1 6 ; DOUT register of the left side (8 LEDs)
#define DEFAULT_SRM_DOUT_R1 9 ; DOUT register of the right side (8 LEDs)
c) 16 “GP LEDs” + 4x16 seperate DUO LED matrix
#define DEFAULT_SRM_DOUT_CATHODES1 6 ; SHOULD be selected with DUO LEDs (high power consumption)
#define DEFAULT_SRM_DOUT_DUOCOLOUR 1 ; DUO colour LEDs
#define DEFAULT_SRM_DOUT_L2 7 ; only relevant for DUO colour LEDs
#define DEFAULT_SRM_DOUT_R2 10 ; only relevant for DUO colour LEDs
d) 16 “GP LEDs” + 4x16 seperate DUO LED matrix + 4x16 seperate button matrix
The 4x16 additional buttons should only control the step gates (and other assigned triggers)
#define DEFAULT_SRM_BUTTONS_ENABLED 1 ; using button matrix
#define DEFAULT_SRM_BUTTONS_NO_UI 1 ; only control gates (and other assigned triggers) with these buttons
#define DEFAULT_SRM_DIN_L 11 ; DIN register of the left side
#define DEFAULT_SRM_DIN_R 12 ; DIN register of the right side
o there are now 4 additional buttons and LEDs for selecting the
track group (G1=track 1-4, G2=track 5-8, G3=track 9-12, G4=track 13-16)
The pin assignments are made in mios_tables.inc (or within the setup_*.asm file)
[/tt]
P.S.: thanks for your nice feedback!
