In the time i have built & been using the already quite impressive MIOS MidiBox Sequencer. Afew things came to mind with regards to possible feature enhancements…
I will cover some ideas which frequently appear on other ‘common’ midi sequencing/manipulation devices & some possibly new ideas to suggest…
A Random Related Deviation:
Probably the best creatively equipped, commercially produced sequencer, was the short lived Latronic Notron. It was produced on a small scale & dispite its quite amazing feature set, it did not last too long ![]()
I’ve recently located some detailed documentation for the notron & will study it in more detail soon (see links below). I expect the documentation will be a really interesting read for anyone working with, or developing midi sequencers. I’ll add anything interesting i read to this post later on…
Some pictures of the two revisions, of the sexy beast ![]()
New Version & original:
A sound on sound review:
www.soundonsound.com/sos/1997_articles/jun97/latronicnorton.html
Official Documentation:
http://www.synthservices.com/notron/notron_v2.pdf
Other Documentation:
http://www.technomage.freeserve.co.uk/notron.htm
#1 Some Simple’ish ideas which should be acheiveable with the exhisting hardware:
* ‘Musical’ Fast data scrolling function:
The following would be useful for acheiving good results quickly; whilst leaving the option to fine tune later to users preference…
Jump between number based data values according to ‘golden ratio’/‘fraction’ rules. ie: number deviders of 0.25, 0.33, 0.50, 0.66, 0.75, 1, 1.25, 1.33, etc…
When note scrolling - Jump by octave / or through notes of various scales.
Jump Along Note Table by 1/2 (1/4) or full bars.
* Variable Portamento & Slide.
Pitch slides up & down rather than jumps from note to note. Also option to bridge/slide one ‘note’ to the next.
Note: for synths which do not accept portamento; sending pitch bend signals could get close.. if not in itself provide an interesting accidental effect, where a full slide range is not possible.
* Basic Accenting
Automatically Slide notes up/down at end of note.
Modes to slide up/slide down/Random/Relative to next.
* Note ‘Echo’ roll off, with variable fade off over given step lengths. also variable pitch slide up/down.
(maybe even echo out into sucessive cord progressions - will eat resources, i figure tho)
* A ‘scroll through’ cord function on each note.
The ability to select one note (or several in a sequence) and scroll through ‘cords’ to apply to each note.
(saving this as a memory patch might be ‘interesting’ however)
* A curve table to (destructively) apply an adustable ammount of increasing values to a modifier (ie: velocity) between two pre selected beat steps.
This tool would allow rapid creation of ‘snare rolls’ & many other things which depend on such patterns of progression. without all the tedious tweaking from one knob to the next, to get it sounding right. ..would just be a case of tweaking 5 knobs start/end level, ‘curve hump’, curve hump centerpoint & curve centerpoint level.
* Basic Gating
Gating acheived by muting with a ‘square wave’ whereby negative number values invert the muting behavior. Adjustable ‘puse width’. Possibly allow the application of a timing curve against the ‘square wave’ which decreases on/off value incrementally over a defined period of time.
Maybe allow Gater values to be modulated by a Curve Table - ie a ‘groove/swing’ type pattern.
* ‘infinate’ scrolling:
When scrolling through data values/notes; allow an option, which can be turned on&off, for wrapping back to the lowest value available when the highest is reached.
* Copy / Clone Function:
Select beginning & end points for copying (as done with editing selections). Press paste button once to place copy immediately after ‘copy end point’. Press again to paste after first paste. Manually select different paste start point.
Additional useful feature would be to have button combinations to paste inverted data/reversed data/add to exhisting data/subtract from exhisting data being pasted over…
Re-selecting pasted data set to quickly fill a section with the same pattern. is useful for taking a basic key pattern; then applying a series of modifyers over entire length of pattern.
Thanks to the mbseq :), the last bits on an idea i have been working on for the last 4-5 years; to further the potential for computers/techology to be a creative tool have fallen into place. I am really not sure to do with it now.. Though im determined to make it happen somehow…
More to come sometime soon..
thanks for reading ![]()
