thanks again, everybody :)! i found out the differences between the mobius sequencer and the SEQ, so i thought i’d post them here in case someone’s searching for it on this forum one day (as i did before i asked):
* the mobius is only one-track, and afaik it’s still only one-track even if it’s only sequencing a rhythm part. the SEQ, on the other hand, is 16-track, and if some of the tracks you’re sequencing are just rhythm instruments (drums, etc), then you get more than 16 tracks; up to 48 tracks. big advantage!
* the mobius has a “glide” function to allow it to slide between notes like the TB-303 does (though only when using CV-outs, i think: not using MIDI). afaik, the SEQ can’t do this (though if you set the gate time of each note to max, and are sequencing a sound that has portamento, it might work. i’m not sure it will, though, and it’s probably not as good as the real thing)
* the mobius also has an “accent” function, once again like the TB-303. on the SEQ, though, you can individually program the velocity of each note in a sequence, so if you program the sounds on your synth right (to respond to higher/lower velocities), you could probably do a very good emulation with the SEQ. i don’t think the mobius can program individual velocities like the SEQ can.
* the mobius doesn’t seem to have as nice a user-interface as the SEQ: the SEQ has two great big LCD screens, while the mobius has a single 4-ish digit LED screen. similarly, the SEQ has lots of encoders and lots of buttons, while the mobius only has a lot of buttons. encoders are nice
* the mobius seems to be better for sequencing and interfacing with analog gear, as it incorporates a CV-out, and can be used as a CV-midi converter or vice-versa.
i think that’s just about it :)! other than that, they seem to do fairly similar things. if anyone has anything to add or correct, feel free to do so!
-duncan
