Hi all,
Ater my recent “success” with my 9v/5v/GND PSU, and in an attempt to give something back to the MidiBox community, I’m designing a PSU that delivers +12v -12v +9v +5v and GND, so every MBHP module currently available can be powered from it, with clean filtered current. I’ve created a schematic for it (and I’m not very expirienced with electronics, so all comments are welcome!):
The goal is for it to consist of parts that are easily available, for example new from Reichelt, so anybody can build a good, stable PSU capable of powering all modules without the need for complicated tricks and/or unreliable second-hand stuff (after 2 malfunctioning C64 PSU’s this has been a big wish for me, I can’t imagine nobody else would
I’ve tried to build a PCB from the schematic, but as I don’t know the right dimensions of the components, I think that’s not very useful yet.
I’ve looked at my own wishes when designing this thing, and that is to have in 1 box: 4x Core, 4x SID, 3x DOUT+LEDs, 2xDIN, Backlit LCD, LTC, AOUT, additional Filters. I’ve estimated the total load not to exceed 2A, but I believe proper heatsinking of the 7812, 7809, and 7805 are a must. I’m not sure if this schematic could also be used for MidiBox LC, as I haven’t studied it’s power requirements, any advise is welcome.
I’ve read that a Toroid/Ringkern Trafo delivers the cleanest current of all trafo’s. At Reichelt there is this trafo: :“RKT 8012 - Ringkerntrafo, 80 VA, 2x 12 V, 2x 3,33 A”. Is that a good choice, or are there better suitable ones in their catalogue that I haven’t found yet? It’s priced at 15,65 euro.
Hope to hear from you guys soon!
Cheers, Alex.
[edit]
Found this one: “RKT 5012 - Ringkerntrafo, 50 VA, 2x 12 V, 2x 2,08 A” - it’s 2x 2,08 A instead of the 3,33A of the other one, should be enough I guess. Price is 12,30 euro - 3,70 euro lower.
There’s also this one: “RKT 3012 - Ringkerntrafo, 30 VA, 2x 12 V, 2x 1,25 A”. I’m not sure if it can deliver enough current. It’s price is 11,95 euro, only 35 cents cheaper than the 2,08A so I think the 2,08 A is preferrable anyway.
Also lightly modified the schematic, replaced the +9v and +5v 4 1x2 SIL headers with 1 2x4 DIL headers, and replaced the +12v 1x2 SIL header with a 2x5 DIL header (for adittional 4x SID6581). Maybe I should extend the +12v to a 2x6 DIL and the -12 to a 2x2 DIL, so AOUT(LC) and OPL3 can be attached at the same time.
[/edit]
[update]
Alle images were moved to the WIKI: http://www.midibox.org/dokuwiki/northernlightx
[/update]
