MIDIbox power consumption?
How much current does the MIDIbox draw under use? What about the various extension modules? How should I spec the power supply?
Cheers!
500 mA is recommented, especially if a backlit display is used, but MIDIfilter and MIDImerger work also with ca. 100 mA..
quote from the CORE page
Yeah, 500mA should cover most projects, but up to 2A can be required for a MBLC for example. (mine has a 1600mA supply, but if I built another one I’d go for 2A just to make sure.)
as soon as you’re using motor faders, you need much more. Watch out for some corresponding forum posts.
Cheers,
Skunk
