The case is made out of four parts which were cut to 45 degree angle at the ends first and then glued.
WOHHHHH!!! AWESOME WOODWORK!!!
Cleanest version would be the use of a cnc router but i havent one. Would be nice though coz i could feed it
directly from my CAD.
I do have a CNC Router, that I built myself (see the timber on the prophet 5 project) … To be honest you wouldn’t get your woodwork any cleaner looking than you do by hand. You still have to hand finish it.
The only advantage the CNC Router gives you is mm accurate repeatability. So if you were to want to build 50 cases, and have them all the same, then you could set up the machine and feed it the raw material.
But the finished result isn’t going to look any better than your hand work… That is beautiful. In some ways CNC would detract from that, because it’s not then a totally hand made item of unique quality.
Nice work, really nice work, I love it! It just doesn’t get any better than that, no matter how you make it.
nice woodwork one way to get the step in the wood other than using a router is to have a table saw and then you lower the blade to the cut depth you require and then move the guide bar to the cut width you require then pass it through the saw, this gives you a really nice step cut in the wood.
