This posting has disappeared after the server crash, so here the next attempt:
This is the MIDIbox SEQ V3 built by Rio, who didn’t hesitate to use the new firmware, even it’s very bad documented.
Note the 4 individual MIDI Out ports: ![]()
thanks Thorsten. it works fine.
Congratulations on new SEQ. Glad to hear it works fine. I am very interested in your case. It looks like shortened new C64 case. Is it? If it is the case, what have you done with the hole at the back?
Nice 101! ![]()
Nice ![]()
Love the LED’s drilled into the ports!
@Sasa Djuric: the case is, yes right, an newer C64-case, which i’ve shortened. For the backside i’ve taken a wood board, which is shortened for the hole and tight with screws. It wasn’t to problematic. This device is really small. It was again a precision job for installing all PCBs into it.
> Nice 101!
…it is also a good syntheziser device e.g. for atmospherically sounds, but it can only play one instrument at same time, so it’s an good device for masterkeyboard.
@stryd_one: yes this was my own idea
For fast working, i want to know, which IIC-Module is sending data to MIDI-OUT Ports. But i don’t want to drill more hole on the case, so i used the holes from MIDI-Ports with a mount inside for LEDs. It looks nice.
