MIDIbox MM V2.0
MIDIbox MM V2.0 is the first application which has been completely written in C. For myself it is a prototype for the MIOS Wrapper and a nice demonstration example, how HUI protocols can be handled with MIOS.
Another application which will be available soon is the ported MIDIbox LC (it’s nearly finished, but I want to complete the MBSEQ hardware option before the first release - means: you will be able to use a Mackie/Logic Control emulation with your MIDIbox SEQ V2)
In addition I’m planning to port MIDIO128, MIDIbox TC, MIDImon and MIDIbox CV in the next months to improve the re-usablility.
There will also be a new application: MIDIbox KMK (Korg microKontrol) emulation
However, here the changelog for MIDIbox MM
MIDIbox MM V2.0
  o the complete application has been ported to C
    More infos about how to compile the code can be found under
        http://www.ucapps.de/mios_c.html
MIDIbox MM V1.0
Initial version which emulates the Motormix nearly completely:
  o eight motorfaders send and receive position data with 10 bit resolution
  o eight touch sensors can be connected
  o eight virtual pots (rotary encoders) send relative events
  o one additional rotary encoder ("jog wheel") sends relative events
  o all 67 button functions are available
  o all 72 LED functions are available
  o two status digits (7 segment digits)
  o messages are displayed on a 2x40 LCD (only!)
Additionally this application provides following functions:
  o a dirty hack makes it possible to add eight LEDrings to the V-Pots.
    However, the host application must send the absolute V-Pot position
    to the display - currently it only works with Sonar, Cubase doesn't
    get use of the so called "rotary pointer" (see Motormix specification)
  o a layer function which allows to map Motormix button functions and LEDs
    to a smaller number of buttons (additional "Shift Key")
  o 128 general purpose controllers can be send with the V-Pots in
    GPC mode
  o optional "dont-send-if-touchsensor-not-pressed" function (disabled by
    default to avoid confusion, but heavily recommented if touchsensors
    available)
Following function of the original Motormix is not implemented:
  o different graphical forms of the "rotary pointers" at the lower
    LCD line, since the graphics are not documented.
    Instead, always a vertical bar + the decimal value will be displayed
Additional Notes:
  o Meters are not supported by the Motormix protocol
  o MTC digits are not supported by the Motormix protocol
  o LEDrings normaly not supported by the Motormix protocol. The
    LEDring hack works only with Sonar, and not with Cubase
  o the two 7 segment digits have to be connected directly to the
    shift registers --- no multiplexing required
  o only one 2x40 LCD is supported by the Motormix protocol
  o tested with the MIDIbox NG hardware, buttons and LEDs are
    assigned according to the existing design. The mapping can be
    changed in mm_io_tables.inc
  o *IMPORTANT* since I'm a Logic user (and therefore prefer the
    Logic Control emulation), this application has only be tested
    with following demo programs:
        o Sonar 3 Producer Demo Edition
        o Cubase SX Demo V1.02
    No guarantee that it also works with other versions
  o Note for Cubase users: most buttons are not assigned to a
    function by default - you have to do this by hand in
    the device configuration! It seems that these functions don't
    have a LED feedback, but this could be different in newer
    Cubase versions. Please read also the "Remote Control Devices"
    Documentation which can be found at the Steinberg Website
[/code]
Does this mean we may be able to port the midiboxes to different chipsets down the road? :slight_smile:
*cough*midibox dsp*cough* 8) :stuck_out_tongue:
