hola a todos quisiera saber si construyo una midibox esta sera compatiple con mi mac powerbook g4 ¿alquien que use mac?
Hola, …sorry, can’t speak español, but there are indeed some of us using Macs. I don’t know what you want to do with it, if you want to code your own applications, see here: http://www.midibox.org/dokuwiki/doku.php?id=how_to_use_xcode2_as_ide_on_a_mac
For a normal Midibox (eg MB64E) the OS makes no difference, as everything is done by MIDI (you need a MIDI-extension box or card, of course).
You just need a pre-burned pic that contains the first level bootloader, because afaik there is no bootloader burn-software available for the mac. But SmashTV or Mike also sell preburned PICs!
(hope this helps ![]()
Cheers,
Michael
creo que no existe diferencia entre mac y pc porque todo se controla via MIDI y pues el midi no tiene que ver con mac o pc.
