I already manufactured MIDIBOX64 and MIDIBOX LC, has the LTC module .
Now the question is ?
I need MIDIBOX LC logic the control button ?48buttons??Also needs MIDIBOX64 64 fader ?Changes again the LTC module the USB module .
Ask how makes concrete should design, can logic control (button) and MIDIBOX64 (fader) also uses,Uses for to control the PC software.
PS: I existing need to control the PC software, the MIDIBOX64 button use has the question, but the MIDIBOX LC button does not have the question, but fader actually has 8
USB module I have manufacture PIC18F4550, probably has the question, wants to use AN2131SC, did not know that has the question?
TRANSL:
"I already built MIDIBOX64 and MIDIBOX LC, with a LTC module.
I need MIDIBOX LC’s control buttons ?48buttons) but I also need 64 faders from MIDIBOX64, as well as he LTC module and the USB module.
May I ask how can I make a concrete design, can I combine logic control buttons and 64 faders of a MIDIBOX64 to control the PC software?
PS: I already tried to control PC software, the MIDIBOX64 button use [i.e. using the MB64 application i suppose, akcija] had problems [he wrote that the pots worked well but MIOS hung up as soon as he pressed a button and LEDs all lit up, lots of random MIDI events arrived at the PC], but if using the MIDIBOX LC app, buttons do not have problems [the buttons work well], but I then I of course have only 8 faders.
I built the USB module with a PIC18F4550, probably that is the problem, should I use AN2131SC?"
