Is it possible to add the mtc display 88888888 to the MB lc like the original Mackie? does it require a 2nd core with the last MTC board ?
Is it possible to add the channel assignement display 88 ( 8 digits leds) to the MB LC ?
Is it possible to connect a 8 chanel extension to the main MB LC that will be driven like the original Mackie LC desk mixer , without problem of chanel and CC control assignement???
Thank you for your answer, And your great work.
You make a great work thorsten!!! thank you.
PS:
Do you think about making the use of the 5" display possible for the midibox LC???
you will notice that the MTC and status digits are already displayed
Unfortunately it isn’t possible to add a LC extension without a second core, since the “stupid” protocol demands for a dedicated MIDI interface for each device. :-/
I’m a little blind! I’ve not seen the TC displayed under the pots setup, on the picture :o
You think about everything thorsten. You’re brillant!
According what you’ve said juste before, it’s seems to be possible to add an extension to the main Midibox LC but with a second core .Right I think I’ll do that way.
I’ll make a 16 chanels desk so. with two cores ( like 2 Mdibox LC ).
But Is it possible to control the extension faders with the main desk selection buttons ( FX, send ,EQ select..)
Like in the mackie XT, because the XT has no buttons on the right.
the XT is controlled by the host application over a second MIDI interface, you are able to setup the host app. on a way that it automatically extends the fader groups - the firmware itself doesn’t require any change for this setup.
