I don’t know about the new Mackie control units… but with the original mackie/Logic control, with logic, the units have to be kept as separate units, even though you could put them both inside one enclosure, like Axel’s setup.
Anyone know more about the new Mackie protocols and/or cubase SX setups? (I presume you mean cubase SX, it won’t work on Cubase 5.1, only as a generic controller)
I mean Cubase SL (for the moment…SX perhaps later).
I think, if noone knew it better, I build both units in one case. Then I can test it and if it’s working I can change the frontpanel again (hard work … but if theres no other way).
Why would you need to re-build the front panel? Have a look at Axel’s midibox. He has two LC’s under one panel, one of them just has the extra features removed, that already appear on the master unit.
I hope I understood what you meant.
Anyway, how do you find cubase SL?
Any good for mixing audio?
I considered SL, but went for the Logic Big Box instead. (version 5, since I was going to use it on a PC… Will have to crossgrade in the future, if I out-grow it though …)
i have looked at Axels Box. But he is using it for logic, I think.
My problem is, I don’t know exactly wich functions I can leave out (without missing them later …) on the second one. 8)
On the cubase layout you have 8 Buttons for Fader groups (which are controlling 8 Faders each, if I understood the manual right). What is happening now, if I build 2x8 Fader Groups. Am I able to control 16 groups with each 16 Faders or not ??? -or shall I leave it to 8 Fader groups. But can these fader groups then control 16 fader ?
You see - a lot of questions by now.
Thats why I thougt, I first build a release with a lot of more knobs & leds I’ll need. Then I can make a new layout after finding out what is possible or not.
Don’t know if I’m right.
Doc
I bought Cubase SL but I haven’t installed it yet. I want to get my box ready first. I know this isn’t a quite good way. But somewhere I have to start…
