MIDIbox FM without sample-playback
Hi:
MBFM has uses a wavetable sequencer. Does this mean it sounds significantly different from OPL3? OPL3 uses pure FM.
Also, is there a way to disable the sample-playback and just use the FM?
I have an SB16 ISA card with OPL3, I like playing MIDIs through it. Will those MIDIs sound the same if I play them through MBFM. I hope so.
Thanks a bunch,
Green
MBFM sounds *just* like OPL3, cause it is nothing more like an OPL3 chip with additional hardware and software. Wavetable sequencer has nothing common with wavetable synthesis, it’s just a sophisticated tracker-like modulation source that makes possible to change every parameter stepwise. So there’s no sample playback available at all.
there are some sound samples that show how the MB FM sounds:
http://www.ucapps.de/midibox_fm.html
http://www.midibox.org/forum/index.php/topic,4004.0.html
