MIDIbox FM background noise [solved]
Hello, friends!
Can you please listen to attached mp3 and tell, is it normal, or something wrong?
Noise remains when i disconnect LCD and CS from the core.
So far i can not exclude PSU (it’s one from dvd player +12v/-12v/+5v) but noise lasts about half a second after switching PSU off.
Cable from core to OPL3 board is about 12cm, soldered directly to core.
Thanks in advance.
And the OPL3 +5v led lights with only J2 connected.
[MBFM_noise.mp3](< base_url >/applications/core/interface/file/attachment.php?id=9453)
Although not easy, i would try a different PSU. The PSU is probably a switcher, which can cause noise if the switching frequency is low.
It sounds like the noise is coming from the LED switching matrix, this could be the result of a certain coupling between the 5V and +/-12V voltage domain.
Try the following:
  • ensure that the ground of the audio jacks + the OPL3 board is directly connected to the ground of the PSU (and not to the core module)
  • add 100 uF caps between ground an the -12V and +12V supply input of the MBHP_OPL3 module (take care for the polarity!)
  • if this still doesn’t help, add 10 Ohm resistors in serial between the +12V and -12V output of your PSU and the appr. MBHP_OPL3 inputs, this helps to decouple the noise as well!
Have no words to thank you, Thorsten!!!
With 100 uf caps at OPL3 board the noise decreased by half (MBFM_noise_capacitors.mp3)
Than i’ve changed 47 uf PSU caps with 200 uf and added 2x10 ohm resistor
Aaaand the noise disappeared completely!!! (MBFM_noise_capacitors_resistors.mp3) :sorcerer:
conclusion: switching PSU from dvd player can be used in audio apps!
[MBFM_noise_capacitors.mp3](< base_url >/applications/core/interface/file/attachment.php?id=9454)
[MBFM_noise_capacitors_resistors.mp3](< base_url >/applications/core/interface/file/attachment.php?id=9455)
I’ve removed additional caps from OPL3 board and voila!!! No noise at all!
So increasing capacity of PSU output caps + adding 10 ohm resistors totally eliminates the noise.
Very cool!
Great to know that this simple method works! :slight_smile:
I just had this problem, an idle noise in the background, using a TRACO TXL 035-1212D - a quite high end PSU for this application in fairness.
Cured it totally by moving the sleeve of the audio outs to the - on the PSU rather then the one on the Core as i was doing previously..
No need for caps or whatnot, this is a total solution!
