First, sorry about posting on this board, I could not find a Midibox CV usage board…
When working in Mono mode for a channel, pressing and holding one key, and then pressing another key (while the first one is being held) does not produce a new Gate trigger. From my experience with Mono mode, each and every key press will trigger a new Gate event even if other keys are still being held.
This re-trigger in mono mode is quite short (ca. 1 mS), it could be that your analog synth doesn’t get it. There is currently no possibility to increase the delay of the re-trigger event
Just an (unfinished) idea:
If the synth won’t get this short trigger, maybe a “analog” solution may help.
What about this:
Put the trigger signal in an op (wired as impendance follower) to stabilize it and then make it a bit longer. Don’t know how. Maybe just with a cap/resistor (mabe in combination with a 74HC00) at the output of the impendance follower.
