I have been pouring over the vast ammount of information on this site for a number of months. I have learned a great deal and have decided to embark on my first project. However, I cannot seem to find a definative answer to the question of analog input resolution.
What is the resoulution for the analog inputs on the MIDIBox 64?
I have read only one reference to this somewhere in the forum posts stating a maximum of 10 bit resolution. Since there are MIOS configurations for the emulation of Mackie/Logic control (which has 1024 step faders), I can only assume that 10 bit resoultion is possible.
My project consists of 56 rotary potentiometers and 8 linear faders. How many, if any, of these controllers can be configured at 10 bit (1024 step) resolution? 7 bit (128 step) resoultion will NOT be enough for my purposes (at least on faders).
Normally it’s 7 Bit and only the LC MIOS application allows 10 Bit for 8 faders per unit. I think that’s because the host application only works in 10 Bit under the LC emulation.
my undstanding is that the hardware samples at 10bits
and MIOS has this data available but most applications reduce the resolution (and jitter) to fit the 7bit midi CC format. So, yes this is possible but you will need to some code to use it.
So is the 10 bit resolution available on the AIN Module or only the MF Module? Will I need to use a MF Module even if I don’t need motorized faders, if I want them 10bit?
If you plan on going into a computer a great program called Plogue Bidule has an adjustable MIDI CC smoothing function which adds a little latency but really helps out the smoothness of 7bit CC parameter changes.
