Hi All,
3 years ago I build a midibox 64, its been great but it was my first project, I am amazed it still works after how badly I soldered it and I didnt secure the PCBS. Anyway I now need to build an upgrade one that is tour ready and reliable and I would love your advise please on some of the details I got wrong
PLAN - itsl be a 64 pot, 48 button plan with 8 strips and an aux area. Each strip will have 1 fader, 5 pots and 4 buttons with additional pots lined up on the right. I havent yet done plot but I know it in my mind. It will not have any LEDS but I may back light it
PREVIOUS MISTAKES - Last time I had panel mounting pots and faders and then made handmade pcbs for the buttons (bad ones) - drawing and etching with a kit. My biggest mistake was I didnt really understand the principle of connects so I hand solder every wire onto the connectors on the AINS and DINS. so stupid. This time I want to use pcbs (i think) instead. the downside is the worry that the pcb doesnt align with my frontpanel. The upside is the stability and reliability of wiring - so here come the questions
QUESTIONS TO ANSWER PLEASE
1, Should I use pcbs to mount the pots - my main issue is wiring all the + and - wires
2, If I do use pcbs should I design one per strip (skipping the faders) and then route all the connects that need to go to ains and dins to pin headers where I can then connect? or shoudl i aim for the top and try and build one mega pcb for the components (i plan to use smash’s pcbs for the main parts)
- I was going to mount the pcbs beneath the frontpanel in parallel - i see bcbox mounted everything perpendicular - is that a better idea - what would you do?
4, if I mount pin headers on my pcbs and use the ones that come with smash boards then I am hoping I can use connectors to easily hook up the two - does this work well and will i need to make up the cables.
Thanks in advance for your help - i know for some these are ridiculous questions but I have searched alot and really need people who know betters opinions. Thanks in advance
Toby
