Midibox 64 freeze
Hi all,
when I mute all 16 buttons (leds are on) my midibox freezes after ca. 45 sec. (lcd light off and no function)
Anyone knows this problem? - Please help!
Thomas
Hi Thomas,
I guess your MB Powersupply (+5V) goes down when all the LED’s switched on - in this case a heat sink element (for the 7805) is a potential solution…
Good Luck!
  • Lemonhorse
:smiley:
Thank you! It looks like I use to much power. It’s better now, but the 7805 is still getting very hot.
Maybe I have to use low power leds…
Thomas
Rather than using low power LEDs
I think you can just use a larger value (or extra)Resistor?
Maybe build another power suplly for the dout module… (with an other 7805)…a led need 0.025A, or less (0.01), the 7805 is for 1A max (0.5A is good)… so  with the 220 resistor on the DOUT, you have 0.022A per leds, which make 44 leds max! (44 led on at the same time).
And I don’t care about the rest of the midibox! (LCD, pic ect…)
