MIDi translator BOX
Hi at all,
I’m newbie for this forum. I’m guitarist and stompboxes DIYers from long time.
My last project (builded, see images) was a programmable MIDI looper 16channels, for switch (via relays) analog audio signal (send/return from stompboxes) from guitar to amplifier. The goal was to change the mix of the guitar effects sequence.
Now I want to build a box (similar at the BOME box product, but with more simple functions) that:
  • has a MIDI input program change (1-128), via MIDI pedalboard (or other device);
  • stores internally a routing path, via “translation matrix”;
  • has a MIDI output changed (in according with a translation matrix).
For exeple: if I send the MIDI PC n.4 into the box, from output the box put  the MIDI PC n.30.
The matrix is simple (for sample):
IN | OUT
1 | 25
2 | 25
3 | 25
4 | 30
This type of project was discussed in this forum? Is similar at the “MIDi mapper” project?
Thanks for your patience.
on the hardware side:
this: http://www.ucapps.de/mbhp_core_stm32f4.html
& this: http://www.ucapps.de/mbhp_midi_io.html
software side:
look if this handle your needs: http://www.ucapps.de/midibox_ng.html
elsewhere:
this code doesnt look very complex, you can program it on your own with MIOS, by simple looking @ the tutorials: http://www.ucapps.de/mios32_c.html
Tutorial 2 (receiving midi)
Tutorial 4 (sending midi)
if you have any problems by storing “Presets” to SD-Card:
< base_url >/topic/19328-sd-card-readwrite-howto-solved/?do=embed&embedComment=168779&embedDo=findComment
the other question how you want to handle “what should it do” via UI (2x20 Display with Encoders under it and 2 Buttons?) aka Preset Editing - or should it do this things hardcodet (without UI)
the hardest thing i had first was to setup the ToolChain, Environment Variables and so on (programming environment on Windows Linux Mac).
and so on.
