midi to parallel
hi all,
many modern notebooks have not a serial port.
On the contrary almost all have a parallel port.
who could develop a midi to parallel adapter?
P.S: i found this link: http://www.xs4all.nl/~marcmarc/ele/sm/midicent.htm
but there are no drivers…
I see it like that: Nearly every normal computer has an serial port. So that 2COM Interface is alright for those.
As a parallel port has much higher data transfer rates a parallel to MIDI would be like shooting mosquitos with a bazooka.
For laptops the USB2MIDI Interface is ideal, isnt it? Its small, it needs no additional power supply and you even have an extra MIDI i/o port! So there is not really any need for an parallel2MIDI thing, is there?
Look up the USB device on ucapps.com (in the MBHP). There are also the drivers downloadable.
P.S.: There are very cheap gameport2MIDI cables with drivers available in good music shops. If you have a gameport, you could try this, too.
