keyboard to the MIDI thru port on the MIDIBox Plus
and thus be able to use my Keyboard aswell as the MIDIBox Plus at the same time? (Thus I dont have to pull out one device to use the other on the MIDI in on the computer..?) If not, what is the MIDI Thru used for?
I have modified the Dave wheelers schematic to incorporate the MIDI Thru.. Is it ok to have both the
MIDI In aswell as the MIDI thru connected to the Rx pin on the PIC at the same time?
…“Some instruments have a third MIDI jack labeled “Thru”. This is used as if it were an OUT jack, and therefore you attach a THRU jack only to another instrument’s IN jack. In fact, the THRU jack is exactly like the OUT jack with one important difference. Any signals that the instrument itself creates (or modifies) are sent out its MIDI OUT jack but not the MIDI THRU jack. Think of the THRU jack as a stream-lined, unprocessed MIDI OUT jack.”… Â
