hello again…
at the moment I’m wondering how to connect a midi thru to mid SID.
where do i connect the LTC? as the port is allready used for the core interconnection…
best,
julian, gettig closer to the finished box.. ^^
hello again…
best,
Hi Julian,
so long the LTC is used in passive mode (MAX232 not connected), you can connect the LTC in parallel to the other core modules - it’s just a “signal reader” in this case, the 74HC00 amplifies the Tx and Rx signal so that the additional LEDs/MIDI ports don’t load the signal line
thanks!
tryed it and it works now ![]()
bst,
julian
