libportmidi shows the port-names as:
found in device ‘Midi Through Port-0’ with interf ‘ALSA’
found out device ‘Midi Through Port-0’ with interf ‘ALSA’
while OSX shows them as:
found in device ‘USB-MIDI-Gerät’ with interf ‘CoreMIDI’
found out device ‘USB-MIDI-Gerät’ with interf ‘CoreMIDI’
How can I customize the Port names ?
I have a KORG NanoKontroll and it has custom (and consistent) port names on Linux and OSX.
thank you!
Sebastian
The KORG nanokontroll probably has drivers which take care of this.
CoreMIDI and ALSA sound like names from the build in drivers from the OS. So not sure how you would fix this. Maybe with some kexts and kernel driver hacking. But that seems like a lot of trouble to me.
I don’t want to change the interface name, but the device name.
And no, the KORG does not have drivers that take care of that.
got it working:
you have to use “#define USB_SUPPORT_USER_STRING_DESC” in the stm32f4 usb driver
set string indexes in the jack definition correctly
and implement the “GetUsrStrDescriptor” callback.
now I have consistent and custom device names for each midi jack.
T.K
July 26, 2014, 12:33am
5
You are a champ!
Could you please elaborate what you’ve changed exactly?
