All other MIDI OUT from the MIDI_IO modules and the two Quad IIc are working fine with the MB SID, but for some strange reason not OUT 4
I have tested it with both MIDI-OX and Send SX, and normal MIDI messages are sent like clock and note on and off.
Is there a reason that the UART for MIDI OUT 4 should not work with MB SID?
I have 4 different MB SID V2, 2 are sammichSIDs and I have the same problem with all. They don’t work on MIDI OUT 4, but work fine on all the other OUTs, and other synths seem to work on OUT 4, and the MIDI messages looks fine.
I have even tried with a different DISCO board, and checked all connections with a multi meter. Same problem and no bad connections.
Have you tried earlier revs (i.e. before 092)? If you find that earlier versions work, then it sure is a software bug.
I remember that some MIDI outs that are based on 3.3V are problematic with some MIDI gear that expects the “regular” 5V sources (this seems to be an issue even though MIDI is essentially a current loop). Maybe there are some tolerances between the Outs on your board that you hit?
I have tried 088 as well, and it’s the same problem, so I don’t think it’s a bug.
I thought the MIDI OUTs where 5V?
Quote
J 11 E
“This port provides four MIDI IOs at ca. 5V level (the pin is configured in open-drain mode, so that a resistor connected between the MOx pins and 5V can pull the output level to 3V or 5V. Normally this pull-up resistor is not required if an opto coupler is used at the receiver side)
Interface to the MBHP_MIDI_IO breakout board.”
What is this pull up resistor that is mentioned here?
Is this something I should add?
The strange thing is that it only affects OUT 4, and only MB SIDs
Is it possible to measure the output with a multimeter?
R5 and R10 are the output pullups. As Il said, the voltage is not as important as the current, which I believe is moreso configured on the opto side.
Some hacks that spring to mind:
Separate the power/grounds of the devices. With an optoisolated input, this shouldn’t be a problem, but often loops can cause issues.
Try to buffer O4 through another MIDI device, if it works then the problem is electrical.
Disable your second quad I2C module by defining fewer ports in the SEQ app (and disconnecting the second module). It could be that the increased latency causes timing mismatches.
Do you mean that I should connect the two power supplies to different wall sockets?
The power supplies are not earthed/grounded.
I’ll see if I can find a unit with MIDI thru.
If it works, and the problem is electrical, what does that mean?
Do the SEQ and SIDs share the same power rails (I guess not, as one is +5V and the other is +9 or so). They will be electrically isolated if you have separate transformer-based PSUs
Not sure, maybe an issue with the STM pin?
OK, that should be easy to test
A long shot, as you’re not even using the Quad I2C, but it is “pushing the limits” to have double quads.
Sounds like a faulty resistor R8 or R10, or wrong value installed? Unpower the unit and measure resistance across R8 and then R10, both should read 220 Ohms.
If that doesn’t help, check resistance between M- on J6 of the MIDI IO board and pin PC12 on the STM32F4 board - this should also be 220 Ohms.
These errors are a pain to find the root for, but it’s better than having to search for an error that only shows every now and then…
