MIDI Messgae path
If I plug  MIDI keyboard to Midbox via MIDI IN will MIDI messages from keyboard translate to MIDI OUT, or I have to implement MIDI Thru ?
Just enable the MIDI-Merger in the Config. - submenu of your MIDIBox!
(Look at the Tutorial:http://www.ucapps.de/midibox64e_tutorial_en.html)
Also, the section “MIDIbox wiring” on the midibox64 tutorial can be of use: http://www.ucapps.de/midibox64_tutorial_en.html
cheers
Thank you. As usual RTFM is the best way to solve a problem :slight_smile:
