Midi Message Filter
Hi Forum,
i wonder if anyone solved the task of filtering midimessages
using the NG application.
I have a stream coming in at a midi port which contains sysex and information
within midi channels 1-8 which confuses other equipment that needs just the informations
of channel 9-16.
I tried to use the router and set up nodes for channel  9-16 - but the sysex stuff gets through anyways.
How can i solve that problem?
Thanks in advance for any answers :smile:
The router doesn’t support more sophisticated filter functions.
I’ve no simple solution for this yet.
hey thorsten,
thank you for clearification.
i have to find another way then.
its mainly because of the sysex data.
there seems to be some serious sysex mess
in that stream coming from - what coincidence -
from a virus ti…
It should be possible to disable SysEx in the Virus TI configuration.
See also http://www.peter.boda.sk/download/Virus_TI_Manual.pdf
Page 131, “MIDI Control” - keyword SysEx
hi thorsten,
you are right - one can switch “high page” parameters (those parameters which can´t be covered by the cc-limit of 127) from sysex to poly pressure (aftertouch). that would be a route to try. and so have i. here are the outputs of a controller dump, one time with the configuration “high page: poly pressure” and one with “high page: sysex”. it seems, that there is some sysex transmitted within both configurations nonetheless. look here:
channel 8 controller dump (page high - poly pressure)
[16566.028] f0 00 00 7e 32 00 0f 4d 49 4f 53 33 32 f7
[16566.230] f0 00 00 7e 32 00 0f 4d 49 4f 53 33 32 f7
[16566.232] f0 00 00 7e 32 00 0f 4d 42 48 50 5f 43 4f 52 45 5f 53 54 4d 33 32 46 34 f7
[16566.234] f0 00 00 7e 32 00 0f 53 54 4d 33 32 46 34 78 78 f7
[16566.237] f0 00 00 7e 32 00 0f 31 30 30 31 36 34 31 33 f7
[16566.239] f0 00 00 7e 32 00 0f 31 46 30 30 33 36 30 30 31 36 34 37 33 32 33 34 33 33 33 32 33 33 33 39 f7
[16566.241] f0 00 00 7e 32 00 0f 31 30 34 38 35 37 36 f7
[16566.244] f0 00 00 7e 32 00 0f 31 39 36 36 30 38 f7
[16566.246] f0 00 00 7e 32 00 0f 4d 49 44 49 62 6f 78 20 4e 47 20 56 31 2e 30 33 32 f7
[16566.248] f0 00 00 7e 32 00 0f 28 43 29 20 32 30 31 34 20 54 2e 4b 6c 6f 73 65 f7
[16605.953] f0 00 20 33 01 10 72 03 1d 04 f7
[16605.956] f0 00 20 33 01 10 72 03 1d 04 f7
[16606.168] f0 00 20 33 01 10 72 04 1d 05 f7
[16606.173] f0 00 20 33 01 10 72 04 1d 05 f7
[16606.353] f0 00 20 33 01 10 72 05 1d 06 f7
[16606.357] f0 00 20 33 01 10 72 05 1d 06 f7
[16606.743] f0 00 20 33 01 10 72 06 1d 07 f7
[16606.747] f0 00 20 33 01 10 72 06 1d 07 f7
[16618.124] fc
[16632.034] b7 05 00   Chn# 8  CC#  5 = 0
[16632.040] b7 0a 40   Chn# 8  CC# 10 = 64
[16632.047] b7 11 00   Chn# 8  CC# 17 = 0
[16632.055] b7 12 00   Chn# 8  CC# 18 = 0
[16632.062] b7 13 00   Chn# 8  CC# 19 = 0
[16632.069] b7 14 40   Chn# 8  CC# 20 = 64
[16632.077] b7 15 40   Chn# 8  CC# 21 = 64
[16632.084] b7 16 00   Chn# 8  CC# 22 = 0
[16632.091] b7 17 00   Chn# 8  CC# 23 = 0
[16632.098] b7 18 00   Chn# 8  CC# 24 = 0
[16632.106] b7 19 1f   Chn# 8  CC# 25 = 31
[16632.113] b7 1a 20   Chn# 8  CC# 26 = 32
[16632.120] b7 1b 30   Chn# 8  CC# 27 = 48
[16632.127] b7 1c 00   Chn# 8  CC# 28 = 0
[16632.135] b7 1d 78   Chn# 8  CC# 29 = 120
[16632.142] b7 1e 40   Chn# 8  CC# 30 = 64
[16632.149] b7 1f 40   Chn# 8  CC# 31 = 64
[16632.156] b7 21 7f   Chn# 8  CC# 33 = 127
[16632.164] b7 22 00   Chn# 8  CC# 34 = 0
[16632.171] b7 23 00   Chn# 8  CC# 35 = 0
[16632.178] b7 24 40   Chn# 8  CC# 36 = 64
[16632.185] b7 25 00   Chn# 8  CC# 37 = 0
[16632.193] b7 27 40   Chn# 8  CC# 39 = 64
[16632.200] b7 28 6a   Chn# 8  CC# 40 = 106
[16632.207] b7 29 69   Chn# 8  CC# 41 = 105
[16632.214] b7 2a 00   Chn# 8  CC# 42 = 0
[16632.222] b7 2b 00   Chn# 8  CC# 43 = 0
[16632.229] b7 2c 00   Chn# 8  CC# 44 = 0
[16632.236] b7 2d 00   Chn# 8  CC# 45 = 0
[16632.243] b7 2e 40   Chn# 8  CC# 46 = 64
[16632.251] b7 2f 40   Chn# 8  CC# 47 = 64
[16632.258] b7 30 40   Chn# 8  CC# 48 = 64
[16632.265] b7 31 00   Chn# 8  CC# 49 = 0
[16632.272] b7 32 00   Chn# 8  CC# 50 = 0
[16632.280] b7 33 00   Chn# 8  CC# 51 = 0
[16632.287] b7 34 00   Chn# 8  CC# 52 = 0
[16632.294] b7 35 00   Chn# 8  CC# 53 = 0
[16632.302] b7 36 00   Chn# 8  CC# 54 = 0
[16632.309] b7 37 17   Chn# 8  CC# 55 = 23
[16632.316] b7 38 00   Chn# 8  CC# 56 = 0
[16632.323] b7 39 40   Chn# 8  CC# 57 = 64
[16632.330] b7 3a 12   Chn# 8  CC# 58 = 18
[16632.338] b7 3b 00   Chn# 8  CC# 59 = 0
[16632.345] b7 3c 47   Chn# 8  CC# 60 = 71
[16632.352] b7 3d 63   Chn# 8  CC# 61 = 99
[16632.360] b7 3e 02   Chn# 8  CC# 62 = 2
[16632.367] b7 3f 12   Chn# 8  CC# 63 = 18
[16632.374] b7 43 30   Chn# 8  CC# 67 = 48
[16632.381] b7 44 01   Chn# 8  CC# 68 = 1
[16632.389] b7 45 00   Chn# 8  CC# 69 = 0
[16632.396] b7 46 00   Chn# 8  CC# 70 = 0
[16632.403] b7 47 40   Chn# 8  CC# 71 = 64
[16632.410] b7 48 00   Chn# 8  CC# 72 = 0
[16632.418] b7 49 00   Chn# 8  CC# 73 = 0
[16632.425] b7 4a 40   Chn# 8  CC# 74 = 64
[16632.432] b7 4b 40   Chn# 8  CC# 75 = 64
[16632.439] b7 4c 40   Chn# 8  CC# 76 = 64
[16632.447] b7 4d 40   Chn# 8  CC# 77 = 64
[16632.454] b7 4e 40   Chn# 8  CC# 78 = 64
[16632.461] b7 4f 30   Chn# 8  CC# 79 = 48
[16632.468] b7 50 01   Chn# 8  CC# 80 = 1
[16632.476] b7 51 00   Chn# 8  CC# 81 = 0
[16632.483] b7 52 00   Chn# 8  CC# 82 = 0
[16632.490] b7 53 40   Chn# 8  CC# 83 = 64
[16632.497] b7 54 00   Chn# 8  CC# 84 = 0
[16632.505] b7 55 00   Chn# 8  CC# 85 = 0
[16632.512] b7 56 40   Chn# 8  CC# 86 = 64
[16632.519] b7 57 40   Chn# 8  CC# 87 = 64
[16632.526] b7 58 40   Chn# 8  CC# 88 = 64
[16632.534] b7 59 40   Chn# 8  CC# 89 = 64
[16632.541] b7 5a 40   Chn# 8  CC# 90 = 64
[16632.548] b7 5b 5e   Chn# 8  CC# 91 = 94
[16632.555] b7 5d 34   Chn# 8  CC# 93 = 52
[16632.563] b7 5e 00   Chn# 8  CC# 94 = 0
[16632.570] b7 67 01   Chn# 8  CC#103 = 1
[16632.577] b7 68 7f   Chn# 8  CC#104 = 127
[16632.585] b7 69 00   Chn# 8  CC#105 = 0
[16632.592] b7 6a 45   Chn# 8  CC#106 = 69
[16632.599] b7 6b 10   Chn# 8  CC#107 = 16
[16632.606] b7 6c 6f   Chn# 8  CC#108 = 111
[16632.614] b7 6d 40   Chn# 8  CC#109 = 64
[16632.621] b7 6e 01   Chn# 8  CC#110 = 1
[16632.628] b7 6f 00   Chn# 8  CC#111 = 0
[16632.635] b7 70 01   Chn# 8  CC#112 = 1
[16632.642] b7 71 00   Chn# 8  CC#113 = 0
[16632.650] b7 72 40   Chn# 8  CC#114 = 64
[16632.657] b7 73 22   Chn# 8  CC#115 = 34
[16632.664] b7 74 10   Chn# 8  CC#116 = 16
[16632.672] b7 75 0c   Chn# 8  CC#117 = 12
[16632.679] b7 76 01   Chn# 8  CC#118 = 1
[16632.686] b7 77 40   Chn# 8  CC#119 = 64
[16632.693] b7 78 00   Chn# 8  CC#120 = 0
[16632.701] b7 7b 01   Chn# 8  CC#123 = 1
[16632.708] a7 02 00   Chn# 8  Aftertouch d-2 0
[16632.715] a7 03 00   Chn# 8  Aftertouch d#2 0
[16632.722] a7 04 00   Chn# 8  Aftertouch e-2 0
[16632.730] a7 05 40   Chn# 8  Aftertouch f-2 64
[16632.737] a7 06 00   Chn# 8  Aftertouch f#2 0
[16632.744] a7 07 30   Chn# 8  Aftertouch g-2 48
[16632.751] a7 08 01   Chn# 8  Aftertouch g#2 1
[16632.759] a7 09 00   Chn# 8  Aftertouch a-2 0
[16632.766] a7 0a 00   Chn# 8  Aftertouch a#2 0
[16632.773] a7 0b 01   Chn# 8  Aftertouch b-2 1
[16632.780] a7 0c 00   Chn# 8  Aftertouch c-1 0
[16632.788] a7 0d 00   Chn# 8  Aftertouch c#1 0
[16632.795] a7 0f 00   Chn# 8  Aftertouch d#1 0
[16632.809] a7 11 04   Chn# 8  Aftertouch f-1 4
[16632.817] a7 12 00   Chn# 8  Aftertouch f#1 0
[16632.824] a7 13 00   Chn# 8  Aftertouch g-1 0
[16632.831] a7 14 04   Chn# 8  Aftertouch g#1 4
[16632.838] a7 15 00   Chn# 8  Aftertouch a-1 0
[16632.846] a7 19 01   Chn# 8  Aftertouch C#0 1
[16632.853] a7 1a 42   Chn# 8  Aftertouch D-0 66
[16632.860] a7 1b 3e   Chn# 8  Aftertouch D#0 62
[16632.868] a7 1c 01   Chn# 8  Aftertouch E-0 1
[16632.875] a7 1e 01   Chn# 8  Aftertouch F#0 1
[16632.882] a7 1f 01   Chn# 8  Aftertouch G-0 1
[16632.889] a7 20 00   Chn# 8  Aftertouch G#0 0
[16632.896] a7 21 24   Chn# 8  Aftertouch A-0 36
[16632.904] a7 22 00   Chn# 8  Aftertouch A#0 0
[16632.911] a7 23 0a   Chn# 8  Aftertouch B-0 10
[16632.918] a7 24 5b   Chn# 8  Aftertouch C-1 91
[16632.926] a7 26 00   Chn# 8  Aftertouch D-1 0
[16632.933] a7 27 00   Chn# 8  Aftertouch D#1 0
[16632.940] a7 29 03   Chn# 8  Aftertouch F-1 3
[16632.947] a7 2a 00   Chn# 8  Aftertouch F#1 0
[16632.955] a7 2b 39   Chn# 8  Aftertouch G-1 57
[16632.962] a7 2c 2b   Chn# 8  Aftertouch G#1 43
[16632.969] a7 2d 55   Chn# 8  Aftertouch A-1 85
[16632.976] a7 2e 00   Chn# 8  Aftertouch A#1 0
[16632.984] a7 2f 40   Chn# 8  Aftertouch B-1 64
[16632.991] a7 30 40   Chn# 8  Aftertouch C-2 64
[16632.998] a7 31 40   Chn# 8  Aftertouch C#2 64
[16633.005] a7 32 40   Chn# 8  Aftertouch D-2 64
[16633.013] a7 36 40   Chn# 8  Aftertouch F#2 64
[16633.020] a7 37 40   Chn# 8  Aftertouch G-2 64
[16633.027] a7 38 40   Chn# 8  Aftertouch G#2 64
[16633.034] a7 39 40   Chn# 8  Aftertouch A-2 64
[16633.042] a7 3a 00   Chn# 8  Aftertouch A#2 0
[16633.049] a7 3c 40   Chn# 8  Aftertouch C-3 64
[16633.056] a7 3d 40   Chn# 8  Aftertouch C#3 64
[16633.063] a7 3e 01   Chn# 8  Aftertouch D-3 1
[16633.071] a7 3f 05   Chn# 8  Aftertouch D#3 5
[16633.078] a7 40 07   Chn# 8  Aftertouch E-3 7
[16633.085] a7 41 04   Chn# 8  Aftertouch F-3 4
[16633.092] a7 42 3d   Chn# 8  Aftertouch F#3 61
[16633.100] a7 43 00   Chn# 8  Aftertouch G-3 0
[16633.107] a7 44 00   Chn# 8  Aftertouch G#3 0
[16633.114] a7 45 40   Chn# 8  Aftertouch A-3 64
[16633.121] a7 46 00   Chn# 8  Aftertouch A#3 0
[16633.129] a7 47 40   Chn# 8  Aftertouch B-3 64
[16633.136] a7 48 00   Chn# 8  Aftertouch C-4 0
[16633.143] a7 49 00   Chn# 8  Aftertouch C#4 0
[16633.151] a7 4a 40   Chn# 8  Aftertouch D-4 64
[16633.158] a7 4b 00   Chn# 8  Aftertouch D#4 0
[16633.165] a7 4c 40   Chn# 8  Aftertouch E-4 64
[16633.172] a7 4d 00   Chn# 8  Aftertouch F-4 0
[16633.179] a7 4e 40   Chn# 8  Aftertouch F#4 64
[16633.187] a7 4f 00   Chn# 8  Aftertouch G-4 0
[16633.194] a7 50 40   Chn# 8  Aftertouch G#4 64
[16633.201] a7 51 00   Chn# 8  Aftertouch A-4 0
[16633.209] a7 52 40   Chn# 8  Aftertouch A#4 64
[16633.216] a7 54 03   Chn# 8  Aftertouch C-5 3
[16633.223] a7 55 00   Chn# 8  Aftertouch C#5 0
[16633.230] a7 56 24   Chn# 8  Aftertouch D-5 36
[16633.238] a7 57 70   Chn# 8  Aftertouch D#5 112
[16633.245] a7 58 30   Chn# 8  Aftertouch E-5 48
[16633.252] a7 59 40   Chn# 8  Aftertouch F-5 64
[16633.259] a7 5a 7f   Chn# 8  Aftertouch F#5 127
[16633.267] a7 5b 00   Chn# 8  Aftertouch G-5 0
[16633.274] a7 5c 40   Chn# 8  Aftertouch G#5 64
[16633.281] a7 5d 4c   Chn# 8  Aftertouch A-5 76
[16633.288] a7 5e 33   Chn# 8  Aftertouch A#5 51
[16633.296] a7 5f 58   Chn# 8  Aftertouch B-5 88
[16633.303] a7 60 40   Chn# 8  Aftertouch C-6 64
[16633.310] a7 61 2b   Chn# 8  Aftertouch C#6 43
[16633.317] a7 62 20   Chn# 8  Aftertouch D-6 32
[16633.325] a7 63 00   Chn# 8  Aftertouch D#6 0
[16633.332] a7 64 00   Chn# 8  Aftertouch E-6 0
[16633.339] a7 65 00   Chn# 8  Aftertouch F-6 0
[16633.346] a7 67 03   Chn# 8  Aftertouch G-6 3
[16633.354] a7 68 5a   Chn# 8  Aftertouch G#6 90
[16633.361] a7 69 57   Chn# 8  Aftertouch A-6 87
[16633.368] a7 6a 05   Chn# 8  Aftertouch A#6 5
[16633.375] a7 6b 61   Chn# 8  Aftertouch B-6 97
[16633.383] a7 6c 4c   Chn# 8  Aftertouch C-7 76
[16633.390] a7 6d 00   Chn# 8  Aftertouch C#7 0
[16633.397] a7 6e 00   Chn# 8  Aftertouch D-7 0
[16633.405] a7 6f 40   Chn# 8  Aftertouch D#7 64
[16633.412] a7 7b 0b   Chn# 8  Aftertouch D#8 11
[16633.419] a7 7c 0a   Chn# 8  Aftertouch E-8 10
[16633.429] f0 00 20 33 01 10 6e 07 01 01 f7
[16633.436] f0 00 20 33 01 10 6e 07 02 00 f7
[16633.443] f0 00 20 33 01 10 6e 07 03 02 f7
[16633.450] f0 00 20 33 01 10 6e 07 04 50 f7
[16633.458] f0 00 20 33 01 10 6e 07 05 14 f7
[16633.465] f0 00 20 33 01 10 6e 07 06 31 f7
[16633.472] f0 00 20 33 01 10 6e 07 07 1c f7
[16633.479] f0 00 20 33 01 10 6e 07 08 00 f7
[16633.487] f0 00 20 33 01 10 6e 07 09 00 f7
[16633.494] f0 00 20 33 01 10 6e 07 0a 00 f7
[16633.501] f0 00 20 33 01 10 6e 07 0c 03 f7
[16633.508] f0 00 20 33 01 10 6e 07 0d 04 f7
[16633.516] f0 00 20 33 01 10 6e 07 0e 02 f7
[16633.523] f0 00 20 33 01 10 6e 07 11 00 f7
[16633.530] f0 00 20 33 01 10 6e 07 13 00 f7
[16633.537] f0 00 20 33 01 10 6e 07 14 7f f7
[16633.545] f0 00 20 33 01 10 6e 07 15 40 f7
[16633.552] f0 00 20 33 01 10 6e 07 16 40 f7
[16633.559] f0 00 20 33 01 10 6e 07 17 7f f7
[16633.566] f0 00 20 33 01 10 6e 07 18 7f f7
[16633.574] f0 00 20 33 01 10 6e 07 19 40 f7
[16633.581] f0 00 20 33 01 10 6e 07 1a 00 f7
[16633.588] f0 00 20 33 01 10 6e 07 1e 00 f7
[16633.596] f0 00 20 33 01 10 6e 07 23 00 f7
[16633.603] f0 00 20 33 01 10 6e 07 25 00 f7
[16633.610] f0 00 20 33 01 10 6e 07 2a 40 f7
[16633.617] f0 00 20 33 01 10 6e 07 2b 00 f7
[16633.625] f0 00 20 33 01 10 6e 07 2c 00 f7
[16633.632] f0 00 20 33 01 10 6e 07 39 00 f7
[16633.639] f0 00 20 33 01 10 6e 07 3e 40 f7
[16633.646] f0 00 20 33 01 10 6e 07 3f 00 f7
[16633.654] f0 00 20 33 01 10 6e 07 40 00 f7
[16633.661] f0 00 20 33 01 10 6e 07 46 00 f7
[16633.668] f0 00 20 33 01 10 6e 07 47 00 f7
[16633.675] f0 00 20 33 01 10 6e 07 48 7f f7
[16633.683] f0 00 20 33 01 10 6e 07 49 7f f7
[16633.690] f0 00 20 33 01 10 6e 07 4a 40 f7
[16633.697] f0 00 20 33 01 10 6e 07 50 14 f7
[16633.704] f0 00 20 33 01 10 6e 07 51 46 f7
[16633.712] f0 00 20 33 01 10 6e 07 52 00 f7
[16633.719] f0 00 20 33 01 10 6e 07 53 40 f7
[16633.726] f0 00 20 33 01 10 6e 07 54 46 f7
[16633.733] f0 00 20 33 01 10 6e 07 55 14 f7
[16633.741] f0 00 20 33 01 10 6e 07 56 46 f7
[16633.748] f0 00 20 33 01 10 6e 07 57 00 f7
[16633.755] f0 00 20 33 01 10 6e 07 58 40 f7
[16633.762] f0 00 20 33 01 10 6e 07 59 46 f7
[16633.770] f0 00 20 33 01 10 6e 07 5a 00 f7
[16633.777] f0 00 20 33 01 10 6e 07 5b 40 f7
[16633.784] f0 00 20 33 01 10 6e 07 5c 00 f7
[16633.791] f0 00 20 33 01 10 6e 07 5d 40 f7
[16633.799] f0 00 20 33 01 10 6e 07 5e 00 f7
[16633.806] f0 00 20 33 01 10 6e 07 5f 40 f7
[16633.813] f0 00 20 33 01 10 6e 07 60 00 f7
[16633.820] f0 00 20 33 01 10 6e 07 61 40 f7
[16633.828] f0 00 20 33 01 10 6e 07 62 00 f7
[16633.835] f0 00 20 33 01 10 6e 07 63 40 f7
[16633.842] f0 00 20 33 01 10 6e 07 64 00 f7
[16633.849] f0 00 20 33 01 10 6e 07 65 40 f7
[16633.857] f0 00 20 33 01 10 6e 07 66 00 f7
[16633.864] f0 00 20 33 01 10 6e 07 67 40 f7
[16633.871] f0 00 20 33 01 10 6e 07 68 00 f7
[16633.879] f0 00 20 33 01 10 6e 07 69 40 f7
[16633.886] f0 00 20 33 01 10 6e 07 6a 00 f7
[16633.893] f0 00 20 33 01 10 6e 07 6b 40 f7
[16633.900] f0 00 20 33 01 10 6e 07 7f 1f f7
[16633.908] f0 00 20 33 01 10 6f 07 00 40 f7
[16633.915] f0 00 20 33 01 10 6f 07 01 64 f7
[16633.922] f0 00 20 33 01 10 6f 07 02 01 f7
[16633.929] f0 00 20 33 01 10 6f 07 03 40 f7
[16633.937] f0 00 20 33 01 10 6f 07 04 64 f7
[16633.944] f0 00 20 33 01 10 6f 07 05 00 f7
[16633.951] f0 00 20 33 01 10 6f 07 06 40 f7
[16633.958] f0 00 20 33 01 10 6f 07 07 64 f7
[16633.966] f0 00 20 33 01 10 6f 07 08 01 f7
[16633.973] f0 00 20 33 01 10 6f 07 09 40 f7
[16633.980] f0 00 20 33 01 10 6f 07 0a 64 f7
[16633.987] f0 00 20 33 01 10 6f 07 0b 00 f7
[16633.995] f0 00 20 33 01 10 6f 07 0c 40 f7
[16634.002] f0 00 20 33 01 10 6f 07 0d 64 f7
[16634.009] f0 00 20 33 01 10 6f 07 0e 01 f7
[16634.016] f0 00 20 33 01 10 6f 07 0f 40 f7
[16634.024] f0 00 20 33 01 10 6f 07 10 64 f7
[16634.031] f0 00 20 33 01 10 6f 07 11 00 f7
[16634.038] f0 00 20 33 01 10 6f 07 12 40 f7
[16634.045] f0 00 20 33 01 10 6f 07 13 64 f7
[16634.053] f0 00 20 33 01 10 6f 07 14 01 f7
[16634.060] f0 00 20 33 01 10 6f 07 15 40 f7
[16634.067] f0 00 20 33 01 10 6f 07 16 64 f7
[16634.074] f0 00 20 33 01 10 6f 07 17 00 f7
[16634.082] f0 00 20 33 01 10 6f 07 18 40 f7
[16634.089] f0 00 20 33 01 10 6f 07 19 64 f7
[16634.096] f0 00 20 33 01 10 6f 07 1a 01 f7
[16634.103] f0 00 20 33 01 10 6f 07 1b 40 f7
[16634.111] f0 00 20 33 01 10 6f 07 1c 64 f7
[16634.118] f0 00 20 33 01 10 6f 07 1d 00 f7
[16634.125] f0 00 20 33 01 10 6f 07 1e 40 f7
[16634.133] f0 00 20 33 01 10 6f 07 1f 64 f7
[16634.140] f0 00 20 33 01 10 6f 07 20 01 f7
[16634.147] f0 00 20 33 01 10 6f 07 21 40 f7
[16634.154] f0 00 20 33 01 10 6f 07 22 64 f7
[16634.162] f0 00 20 33 01 10 6f 07 23 00 f7
[16634.169] f0 00 20 33 01 10 6f 07 24 40 f7
[16634.176] f0 00 20 33 01 10 6f 07 25 64 f7
[16634.183] f0 00 20 33 01 10 6f 07 26 01 f7
[16634.191] f0 00 20 33 01 10 6f 07 27 40 f7
[16634.198] f0 00 20 33 01 10 6f 07 28 64 f7
[16634.205] f0 00 20 33 01 10 6f 07 29 00 f7
[16634.212] f0 00 20 33 01 10 6f 07 2a 40 f7
[16634.220] f0 00 20 33 01 10 6f 07 2b 64 f7
[16634.227] f0 00 20 33 01 10 6f 07 2c 01 f7
[16634.234] f0 00 20 33 01 10 6f 07 2d 40 f7
[16634.241] f0 00 20 33 01 10 6f 07 2e 64 f7
[16634.249] f0 00 20 33 01 10 6f 07 2f 00 f7
[16634.256] f0 00 20 33 01 10 6f 07 30 40 f7
[16634.263] f0 00 20 33 01 10 6f 07 31 64 f7
[16634.270] f0 00 20 33 01 10 6f 07 32 01 f7
[16634.278] f0 00 20 33 01 10 6f 07 33 40 f7
[16634.285] f0 00 20 33 01 10 6f 07 34 64 f7
[16634.292] f0 00 20 33 01 10 6f 07 35 00 f7
[16634.299] f0 00 20 33 01 10 6f 07 36 40 f7
[16634.307] f0 00 20 33 01 10 6f 07 37 64 f7
[16634.314] f0 00 20 33 01 10 6f 07 38 01 f7
[16634.321] f0 00 20 33 01 10 6f 07 39 40 f7
[16634.328] f0 00 20 33 01 10 6f 07 3a 64 f7
[16634.336] f0 00 20 33 01 10 6f 07 3b 00 f7
[16634.343] f0 00 20 33 01 10 6f 07 3c 40 f7
[16634.350] f0 00 20 33 01 10 6f 07 3d 64 f7
[16634.357] f0 00 20 33 01 10 6f 07 3e 01 f7
[16634.365] f0 00 20 33 01 10 6f 07 3f 40 f7
[16634.372] f0 00 20 33 01 10 6f 07 40 64 f7
[16634.379] f0 00 20 33 01 10 6f 07 41 00 f7
[16634.387] f0 00 20 33 01 10 6f 07 42 40 f7
[16634.394] f0 00 20 33 01 10 6f 07 43 64 f7
[16634.401] f0 00 20 33 01 10 6f 07 44 01 f7
[16634.408] f0 00 20 33 01 10 6f 07 45 40 f7
[16634.416] f0 00 20 33 01 10 6f 07 46 64 f7
[16634.423] f0 00 20 33 01 10 6f 07 47 00 f7
[16634.430] f0 00 20 33 01 10 6f 07 48 40 f7
[16634.437] f0 00 20 33 01 10 6f 07 49 64 f7
[16634.445] f0 00 20 33 01 10 6f 07 4a 01 f7
[16634.452] f0 00 20 33 01 10 6f 07 4b 40 f7
[16634.459] f0 00 20 33 01 10 6f 07 4c 64 f7
[16634.466] f0 00 20 33 01 10 6f 07 4d 00 f7
[16634.474] f0 00 20 33 01 10 6f 07 4e 40 f7
[16634.481] f0 00 20 33 01 10 6f 07 4f 64 f7
[16634.488] f0 00 20 33 01 10 6f 07 50 01 f7
[16634.495] f0 00 20 33 01 10 6f 07 51 40 f7
[16634.503] f0 00 20 33 01 10 6f 07 52 64 f7
[16634.510] f0 00 20 33 01 10 6f 07 53 00 f7
[16634.517] f0 00 20 33 01 10 6f 07 54 40 f7
[16634.524] f0 00 20 33 01 10 6f 07 55 64 f7
[16634.532] f0 00 20 33 01 10 6f 07 56 01 f7
[16634.539] f0 00 20 33 01 10 6f 07 57 40 f7
[16634.546] f0 00 20 33 01 10 6f 07 58 64 f7
[16634.553] f0 00 20 33 01 10 6f 07 59 00 f7
[16634.561] f0 00 20 33 01 10 6f 07 5a 40 f7
[16634.568] f0 00 20 33 01 10 6f 07 5b 64 f7
[16634.575] f0 00 20 33 01 10 6f 07 5c 01 f7
[16634.582] f0 00 20 33 01 10 6f 07 5d 40 f7
[16634.590] f0 00 20 33 01 10 6f 07 5e 64 f7
[16634.597] f0 00 20 33 01 10 6f 07 5f 00 f7
[16634.604] f0 00 20 33 01 10 6f 07 78 00 f7
[16634.611] f0 00 20 33 01 10 6f 07 79 30 f7
[16634.619] f0 00 20 33 01 10 6f 07 7a 7f f7
[16634.626] f0 00 20 33 01 10 6f 07 7b 40 f7
[16634.633] f0 00 20 33 01 10 6f 07 7c 00 f7
[16634.640] f0 00 20 33 01 10 6f 07 7d 01 f7
[16634.648] f0 00 20 33 01 10 6f 07 7e 00 f7
[16634.655] f0 00 20 33 01 10 6f 07 7f 00 f7
channel 8 controller dump (high page sysex)
[16775.309] b7 05 00   Chn# 8  CC#  5 = 0
[16775.315] b7 0a 40   Chn# 8  CC# 10 = 64
[16775.322] b7 11 00   Chn# 8  CC# 17 = 0
[16775.330] b7 12 00   Chn# 8  CC# 18 = 0
[16775.337] b7 13 00   Chn# 8  CC# 19 = 0
[16775.344] b7 14 40   Chn# 8  CC# 20 = 64
[16775.351] b7 15 40   Chn# 8  CC# 21 = 64
[16775.359] b7 16 00   Chn# 8  CC# 22 = 0
[16775.366] b7 17 00   Chn# 8  CC# 23 = 0
[16775.373] b7 18 00   Chn# 8  CC# 24 = 0
[16775.380] b7 19 1f   Chn# 8  CC# 25 = 31
[16775.388] b7 1a 20   Chn# 8  CC# 26 = 32
[16775.395] b7 1b 30   Chn# 8  CC# 27 = 48
[16775.402] b7 1c 00   Chn# 8  CC# 28 = 0
[16775.409] b7 1d 78   Chn# 8  CC# 29 = 120
[16775.417] b7 1e 40   Chn# 8  CC# 30 = 64
[16775.424] b7 1f 40   Chn# 8  CC# 31 = 64
[16775.431] b7 21 7f   Chn# 8  CC# 33 = 127
[16775.438] b7 22 00   Chn# 8  CC# 34 = 0
[16775.446] b7 23 00   Chn# 8  CC# 35 = 0
[16775.453] b7 24 40   Chn# 8  CC# 36 = 64
[16775.460] b7 25 00   Chn# 8  CC# 37 = 0
[16775.467] b7 27 40   Chn# 8  CC# 39 = 64
[16775.475] b7 28 6a   Chn# 8  CC# 40 = 106
[16775.482] b7 29 69   Chn# 8  CC# 41 = 105
[16775.489] b7 2a 00   Chn# 8  CC# 42 = 0
[16775.496] b7 2b 00   Chn# 8  CC# 43 = 0
[16775.504] b7 2c 00   Chn# 8  CC# 44 = 0
[16775.511] b7 2d 00   Chn# 8  CC# 45 = 0
[16775.518] b7 2e 40   Chn# 8  CC# 46 = 64
[16775.525] b7 2f 40   Chn# 8  CC# 47 = 64
[16775.533] b7 30 40   Chn# 8  CC# 48 = 64
[16775.540] b7 31 00   Chn# 8  CC# 49 = 0
[16775.547] b7 32 00   Chn# 8  CC# 50 = 0
[16775.555] b7 33 00   Chn# 8  CC# 51 = 0
[16775.562] b7 34 00   Chn# 8  CC# 52 = 0
[16775.569] b7 35 00   Chn# 8  CC# 53 = 0
[16775.576] b7 36 00   Chn# 8  CC# 54 = 0
[16775.584] b7 37 17   Chn# 8  CC# 55 = 23
[16775.591] b7 38 00   Chn# 8  CC# 56 = 0
[16775.598] b7 39 40   Chn# 8  CC# 57 = 64
[16775.605] b7 3a 12   Chn# 8  CC# 58 = 18
[16775.613] b7 3b 00   Chn# 8  CC# 59 = 0
[16775.620] b7 3c 47   Chn# 8  CC# 60 = 71
[16775.627] b7 3d 63   Chn# 8  CC# 61 = 99
[16775.634] b7 3e 02   Chn# 8  CC# 62 = 2
[16775.642] b7 3f 12   Chn# 8  CC# 63 = 18
[16775.649] b7 43 30   Chn# 8  CC# 67 = 48
[16775.656] b7 44 01   Chn# 8  CC# 68 = 1
[16775.663] b7 45 00   Chn# 8  CC# 69 = 0
[16775.671] b7 46 00   Chn# 8  CC# 70 = 0
[16775.678] b7 47 40   Chn# 8  CC# 71 = 64
[16775.685] b7 48 00   Chn# 8  CC# 72 = 0
[16775.692] b7 49 00   Chn# 8  CC# 73 = 0
[16775.700] b7 4a 40   Chn# 8  CC# 74 = 64
[16775.707] b7 4b 40   Chn# 8  CC# 75 = 64
[16775.714] b7 4c 40   Chn# 8  CC# 76 = 64
[16775.721] b7 4d 40   Chn# 8  CC# 77 = 64
[16775.729] b7 4e 40   Chn# 8  CC# 78 = 64
[16775.736] b7 4f 30   Chn# 8  CC# 79 = 48
[16775.743] b7 50 01   Chn# 8  CC# 80 = 1
[16775.750] b7 51 00   Chn# 8  CC# 81 = 0
[16775.758] b7 52 00   Chn# 8  CC# 82 = 0
[16775.765] b7 53 40   Chn# 8  CC# 83 = 64
[16775.772] b7 54 00   Chn# 8  CC# 84 = 0
[16775.779] b7 55 00   Chn# 8  CC# 85 = 0
[16775.787] b7 56 40   Chn# 8  CC# 86 = 64
[16775.794] b7 57 40   Chn# 8  CC# 87 = 64
[16775.801] b7 58 40   Chn# 8  CC# 88 = 64
[16775.809] b7 59 40   Chn# 8  CC# 89 = 64
[16775.816] b7 5a 40   Chn# 8  CC# 90 = 64
[16775.823] b7 5b 5e   Chn# 8  CC# 91 = 94
[16775.830] b7 5d 34   Chn# 8  CC# 93 = 52
[16775.837] b7 5e 00   Chn# 8  CC# 94 = 0
[16775.845] b7 67 01   Chn# 8  CC#103 = 1
[16775.852] b7 68 7f   Chn# 8  CC#104 = 127
[16775.858] b7 69 00   Chn# 8  CC#105 = 0
[16775.867] b7 6a 45   Chn# 8  CC#106 = 69
[16775.874] b7 6b 10   Chn# 8  CC#107 = 16
[16775.881] b7 6c 6f   Chn# 8  CC#108 = 111
[16775.888] b7 6d 40   Chn# 8  CC#109 = 64
[16775.896] b7 6e 01   Chn# 8  CC#110 = 1
[16775.903] b7 6f 00   Chn# 8  CC#111 = 0
[16775.910] b7 70 01   Chn# 8  CC#112 = 1
[16775.917] b7 71 00   Chn# 8  CC#113 = 0
[16775.925] b7 72 40   Chn# 8  CC#114 = 64
[16775.932] b7 73 22   Chn# 8  CC#115 = 34
[16775.939] b7 74 10   Chn# 8  CC#116 = 16
[16775.946] b7 75 0c   Chn# 8  CC#117 = 12
[16775.954] b7 76 01   Chn# 8  CC#118 = 1
[16775.960] b7 77 40   Chn# 8  CC#119 = 64
[16775.968] b7 78 00   Chn# 8  CC#120 = 0
[16775.975] b7 7b 01   Chn# 8  CC#123 = 1
[16775.985] f0 00 20 33 01 10 71 07 02 00 f7
[16775.992] f0 00 20 33 01 10 71 07 03 00 f7
[16776.000] f0 00 20 33 01 10 71 07 04 00 f7
[16776.007] f0 00 20 33 01 10 71 07 05 40 f7
[16776.014] f0 00 20 33 01 10 71 07 06 00 f7
[16776.021] f0 00 20 33 01 10 71 07 07 30 f7
[16776.029] f0 00 20 33 01 10 71 07 08 01 f7
[16776.036] f0 00 20 33 01 10 71 07 09 00 f7
[16776.043] f0 00 20 33 01 10 71 07 0a 00 f7
[16776.050] f0 00 20 33 01 10 71 07 0b 01 f7
[16776.058] f0 00 20 33 01 10 71 07 0c 00 f7
[16776.065] f0 00 20 33 01 10 71 07 0d 00 f7
[16776.072] f0 00 20 33 01 10 71 07 0f 00 f7
[16776.087] f0 00 20 33 01 10 71 07 11 04 f7
[16776.094] f0 00 20 33 01 10 71 07 12 00 f7
[16776.100] f0 00 20 33 01 10 71 07 13 00 f7
[16776.108] f0 00 20 33 01 10 71 07 14 04 f7
[16776.116] f0 00 20 33 01 10 71 07 15 00 f7
[16776.123] f0 00 20 33 01 10 71 07 19 01 f7
[16776.130] f0 00 20 33 01 10 71 07 1a 42 f7
[16776.137] f0 00 20 33 01 10 71 07 1b 3e f7
[16776.145] f0 00 20 33 01 10 71 07 1c 01 f7
[16776.152] f0 00 20 33 01 10 71 07 1e 01 f7
[16776.159] f0 00 20 33 01 10 71 07 1f 01 f7
[16776.166] f0 00 20 33 01 10 71 07 20 00 f7
[16776.174] f0 00 20 33 01 10 71 07 21 24 f7
[16776.181] f0 00 20 33 01 10 71 07 22 00 f7
[16776.188] f0 00 20 33 01 10 71 07 23 0a f7
[16776.195] f0 00 20 33 01 10 71 07 24 5b f7
[16776.203] f0 00 20 33 01 10 71 07 26 00 f7
[16776.210] f0 00 20 33 01 10 71 07 27 00 f7
[16776.216] f0 00 20 33 01 10 71 07 29 03 f7
[16776.224] f0 00 20 33 01 10 71 07 2a 00 f7
[16776.232] f0 00 20 33 01 10 71 07 2b 39 f7
[16776.239] f0 00 20 33 01 10 71 07 2c 2b f7
[16776.246] f0 00 20 33 01 10 71 07 2d 55 f7
[16776.254] f0 00 20 33 01 10 71 07 2e 00 f7
[16776.261] f0 00 20 33 01 10 71 07 2f 40 f7
[16776.268] f0 00 20 33 01 10 71 07 30 40 f7
[16776.275] f0 00 20 33 01 10 71 07 31 40 f7
[16776.282] f0 00 20 33 01 10 71 07 32 40 f7
[16776.290] f0 00 20 33 01 10 71 07 36 40 f7
[16776.296] f0 00 20 33 01 10 71 07 37 40 f7
[16776.304] f0 00 20 33 01 10 71 07 38 40 f7
[16776.312] f0 00 20 33 01 10 71 07 39 40 f7
[16776.319] f0 00 20 33 01 10 71 07 3a 00 f7
[16776.326] f0 00 20 33 01 10 71 07 3c 40 f7
[16776.333] f0 00 20 33 01 10 71 07 3d 40 f7
[16776.341] f0 00 20 33 01 10 71 07 3e 01 f7
[16776.348] f0 00 20 33 01 10 71 07 3f 05 f7
[16776.355] f0 00 20 33 01 10 71 07 40 07 f7
[16776.362] f0 00 20 33 01 10 71 07 41 04 f7
[16776.370] f0 00 20 33 01 10 71 07 42 3d f7
[16776.377] f0 00 20 33 01 10 71 07 43 00 f7
[16776.384] f0 00 20 33 01 10 71 07 44 00 f7
[16776.391] f0 00 20 33 01 10 71 07 45 40 f7
[16776.399] f0 00 20 33 01 10 71 07 46 00 f7
[16776.406] f0 00 20 33 01 10 71 07 47 40 f7
[16776.413] f0 00 20 33 01 10 71 07 48 00 f7
[16776.420] f0 00 20 33 01 10 71 07 49 00 f7
[16776.428] f0 00 20 33 01 10 71 07 4a 40 f7
[16776.435] f0 00 20 33 01 10 71 07 4b 00 f7
[16776.442] f0 00 20 33 01 10 71 07 4c 40 f7
[16776.449] f0 00 20 33 01 10 71 07 4d 00 f7
[16776.456] f0 00 20 33 01 10 71 07 4e 40 f7
[16776.464] f0 00 20 33 01 10 71 07 4f 00 f7
[16776.471] f0 00 20 33 01 10 71 07 50 40 f7
[16776.478] f0 00 20 33 01 10 71 07 51 00 f7
[16776.486] f0 00 20 33 01 10 71 07 52 40 f7
[16776.493] f0 00 20 33 01 10 71 07 54 03 f7
[16776.500] f0 00 20 33 01 10 71 07 55 00 f7
[16776.507] f0 00 20 33 01 10 71 07 56 24 f7
[16776.515] f0 00 20 33 01 10 71 07 57 70 f7
[16776.522] f0 00 20 33 01 10 71 07 58 30 f7
[16776.528] f0 00 20 33 01 10 71 07 59 40 f7
[16776.537] f0 00 20 33 01 10 71 07 5a 7f f7
[16776.544] f0 00 20 33 01 10 71 07 5b 00 f7
[16776.553] f0 00 20 33 01 10 71 07 5c 40 f7
[16776.560] f0 00 20 33 01 10 71 07 5d 4c f7
[16776.567] f0 00 20 33 01 10 71 07 5e 33 f7
[16776.574] f0 00 20 33 01 10 71 07 5f 58 f7
[16776.582] f0 00 20 33 01 10 71 07 60 40 f7
[16776.589] f0 00 20 33 01 10 71 07 61 2b f7
[16776.596] f0 00 20 33 01 10 71 07 62 20 f7
[16776.603] f0 00 20 33 01 10 71 07 63 00 f7
[16776.611] f0 00 20 33 01 10 71 07 64 00 f7
[16776.618] f0 00 20 33 01 10 71 07 65 00 f7
[16776.625] f0 00 20 33 01 10 71 07 67 03 f7
[16776.632] f0 00 20 33 01 10 71 07 68 5a f7
[16776.640] f0 00 20 33 01 10 71 07 69 57 f7
[16776.647] f0 00 20 33 01 10 71 07 6a 05 f7
[16776.654] f0 00 20 33 01 10 71 07 6b 61 f7
[16776.661] f0 00 20 33 01 10 71 07 6c 4c f7
[16776.669] f0 00 20 33 01 10 71 07 6d 00 f7
[16776.676] f0 00 20 33 01 10 71 07 6e 00 f7
[16776.683] f0 00 20 33 01 10 71 07 6f 40 f7
[16776.690] f0 00 20 33 01 10 71 07 7b 0b f7
[16776.698] f0 00 20 33 01 10 71 07 7c 0a f7
[16776.705] f0 00 20 33 01 10 6e 07 01 01 f7
[16776.712] f0 00 20 33 01 10 6e 07 02 00 f7
[16776.719] f0 00 20 33 01 10 6e 07 03 02 f7
[16776.727] f0 00 20 33 01 10 6e 07 04 50 f7
[16776.734] f0 00 20 33 01 10 6e 07 05 14 f7
[16776.741] f0 00 20 33 01 10 6e 07 06 31 f7
[16776.748] f0 00 20 33 01 10 6e 07 07 1c f7
[16776.756] f0 00 20 33 01 10 6e 07 08 00 f7
[16776.763] f0 00 20 33 01 10 6e 07 09 00 f7
[16776.770] f0 00 20 33 01 10 6e 07 0a 00 f7
[16776.777] f0 00 20 33 01 10 6e 07 0c 03 f7
[16776.785] f0 00 20 33 01 10 6e 07 0d 04 f7
[16776.792] f0 00 20 33 01 10 6e 07 0e 02 f7
[16776.799] f0 00 20 33 01 10 6e 07 11 00 f7
[16776.806] f0 00 20 33 01 10 6e 07 13 00 f7
[16776.814] f0 00 20 33 01 10 6e 07 14 7f f7
[16776.821] f0 00 20 33 01 10 6e 07 15 40 f7
[16776.828] f0 00 20 33 01 10 6e 07 16 40 f7
[16776.836] f0 00 20 33 01 10 6e 07 17 7f f7
[16776.843] f0 00 20 33 01 10 6e 07 18 7f f7
[16776.850] f0 00 20 33 01 10 6e 07 19 40 f7
[16776.857] f0 00 20 33 01 10 6e 07 1a 00 f7
[16776.864] f0 00 20 33 01 10 6e 07 1e 00 f7
[16776.872] f0 00 20 33 01 10 6e 07 23 00 f7
[16776.879] f0 00 20 33 01 10 6e 07 25 00 f7
[16776.886] f0 00 20 33 01 10 6e 07 2a 40 f7
[16776.894] f0 00 20 33 01 10 6e 07 2b 00 f7
[16776.901] f0 00 20 33 01 10 6e 07 2c 00 f7
[16776.908] f0 00 20 33 01 10 6e 07 39 00 f7
[16776.915] f0 00 20 33 01 10 6e 07 3e 40 f7
[16776.923] f0 00 20 33 01 10 6e 07 3f 00 f7
[16776.930] f0 00 20 33 01 10 6e 07 40 00 f7
[16776.937] f0 00 20 33 01 10 6e 07 46 00 f7
[16776.944] f0 00 20 33 01 10 6e 07 47 00 f7
[16776.952] f0 00 20 33 01 10 6e 07 48 7f f7
[16776.959] f0 00 20 33 01 10 6e 07 49 7f f7
[16776.966] f0 00 20 33 01 10 6e 07 4a 40 f7
[16776.973] f0 00 20 33 01 10 6e 07 50 14 f7
[16776.981] f0 00 20 33 01 10 6e 07 51 46 f7
[16776.988] f0 00 20 33 01 10 6e 07 52 00 f7
[16776.995] f0 00 20 33 01 10 6e 07 53 40 f7
[16777.002] f0 00 20 33 01 10 6e 07 54 46 f7
[16777.010] f0 00 20 33 01 10 6e 07 55 14 f7
[16777.017] f0 00 20 33 01 10 6e 07 56 46 f7
[16777.024] f0 00 20 33 01 10 6e 07 57 00 f7
[16777.031] f0 00 20 33 01 10 6e 07 58 40 f7
[16777.039] f0 00 20 33 01 10 6e 07 59 46 f7
[16777.046] f0 00 20 33 01 10 6e 07 5a 00 f7
[16777.053] f0 00 20 33 01 10 6e 07 5b 40 f7
[16777.060] f0 00 20 33 01 10 6e 07 5c 00 f7
[16777.068] f0 00 20 33 01 10 6e 07 5d 40 f7
[16777.075] f0 00 20 33 01 10 6e 07 5e 00 f7
[16777.082] f0 00 20 33 01 10 6e 07 5f 40 f7
[16777.089] f0 00 20 33 01 10 6e 07 60 00 f7
[16777.096] f0 00 20 33 01 10 6e 07 61 40 f7
[16777.104] f0 00 20 33 01 10 6e 07 62 00 f7
[16777.111] f0 00 20 33 01 10 6e 07 63 40 f7
[16777.118] f0 00 20 33 01 10 6e 07 64 00 f7
[16777.126] f0 00 20 33 01 10 6e 07 65 40 f7
[16777.133] f0 00 20 33 01 10 6e 07 66 00 f7
[16777.140] f0 00 20 33 01 10 6e 07 67 40 f7
[16777.147] f0 00 20 33 01 10 6e 07 68 00 f7
[16777.155] f0 00 20 33 01 10 6e 07 69 40 f7
[16777.162] f0 00 20 33 01 10 6e 07 6a 00 f7
[16777.169] f0 00 20 33 01 10 6e 07 6b 40 f7
[16777.177] f0 00 20 33 01 10 6e 07 7f 1f f7
[16777.184] f0 00 20 33 01 10 6f 07 00 40 f7
[16777.191] f0 00 20 33 01 10 6f 07 01 64 f7
[16777.198] f0 00 20 33 01 10 6f 07 02 01 f7
[16777.206] f0 00 20 33 01 10 6f 07 03 40 f7
[16777.213] f0 00 20 33 01 10 6f 07 04 64 f7
[16777.220] f0 00 20 33 01 10 6f 07 05 00 f7
[16777.227] f0 00 20 33 01 10 6f 07 06 40 f7
[16777.235] f0 00 20 33 01 10 6f 07 07 64 f7
[16777.242] f0 00 20 33 01 10 6f 07 08 01 f7
[16777.249] f0 00 20 33 01 10 6f 07 09 40 f7
[16777.256] f0 00 20 33 01 10 6f 07 0a 64 f7
[16777.264] f0 00 20 33 01 10 6f 07 0b 00 f7
[16777.271] f0 00 20 33 01 10 6f 07 0c 40 f7
[16777.277] f0 00 20 33 01 10 6f 07 0d 64 f7
[16777.285] f0 00 20 33 01 10 6f 07 0e 01 f7
[16777.293] f0 00 20 33 01 10 6f 07 0f 40 f7
[16777.299] f0 00 20 33 01 10 6f 07 10 64 f7
[16777.307] f0 00 20 33 01 10 6f 07 11 00 f7
[16777.314] f0 00 20 33 01 10 6f 07 12 40 f7
[16777.322] f0 00 20 33 01 10 6f 07 13 64 f7
[16777.329] f0 00 20 33 01 10 6f 07 14 01 f7
[16777.336] f0 00 20 33 01 10 6f 07 15 40 f7
[16777.343] f0 00 20 33 01 10 6f 07 16 64 f7
[16777.351] f0 00 20 33 01 10 6f 07 17 00 f7
[16777.358] f0 00 20 33 01 10 6f 07 18 40 f7
[16777.365] f0 00 20 33 01 10 6f 07 19 64 f7
[16777.373] f0 00 20 33 01 10 6f 07 1a 01 f7
[16777.380] f0 00 20 33 01 10 6f 07 1b 40 f7
[16777.387] f0 00 20 33 01 10 6f 07 1c 64 f7
[16777.394] f0 00 20 33 01 10 6f 07 1d 00 f7
[16777.402] f0 00 20 33 01 10 6f 07 1e 40 f7
[16777.409] f0 00 20 33 01 10 6f 07 1f 64 f7
[16777.416] f0 00 20 33 01 10 6f 07 20 01 f7
[16777.423] f0 00 20 33 01 10 6f 07 21 40 f7
[16777.431] f0 00 20 33 01 10 6f 07 22 64 f7
[16777.438] f0 00 20 33 01 10 6f 07 23 00 f7
[16777.445] f0 00 20 33 01 10 6f 07 24 40 f7
[16777.452] f0 00 20 33 01 10 6f 07 25 64 f7
[16777.460] f0 00 20 33 01 10 6f 07 26 01 f7
[16777.467] f0 00 20 33 01 10 6f 07 27 40 f7
[16777.474] f0 00 20 33 01 10 6f 07 28 64 f7
[16777.481] f0 00 20 33 01 10 6f 07 29 00 f7
[16777.489] f0 00 20 33 01 10 6f 07 2a 40 f7
[16777.496] f0 00 20 33 01 10 6f 07 2b 64 f7
[16777.503] f0 00 20 33 01 10 6f 07 2c 01 f7
[16777.510] f0 00 20 33 01 10 6f 07 2d 40 f7
[16777.518] f0 00 20 33 01 10 6f 07 2e 64 f7
[16777.525] f0 00 20 33 01 10 6f 07 2f 00 f7
[16777.532] f0 00 20 33 01 10 6f 07 30 40 f7
[16777.539] f0 00 20 33 01 10 6f 07 31 64 f7
[16777.547] f0 00 20 33 01 10 6f 07 32 01 f7
[16777.554] f0 00 20 33 01 10 6f 07 33 40 f7
[16777.561] f0 00 20 33 01 10 6f 07 34 64 f7
[16777.568] f0 00 20 33 01 10 6f 07 35 00 f7
[16777.576] f0 00 20 33 01 10 6f 07 36 40 f7
[16777.583] f0 00 20 33 01 10 6f 07 37 64 f7
[16777.590] f0 00 20 33 01 10 6f 07 38 01 f7
[16777.597] f0 00 20 33 01 10 6f 07 39 40 f7
[16777.605] f0 00 20 33 01 10 6f 07 3a 64 f7
[16777.612] f0 00 20 33 01 10 6f 07 3b 00 f7
[16777.619] f0 00 20 33 01 10 6f 07 3c 40 f7
[16777.626] f0 00 20 33 01 10 6f 07 3d 64 f7
[16777.634] f0 00 20 33 01 10 6f 07 3e 01 f7
[16777.641] f0 00 20 33 01 10 6f 07 3f 40 f7
[16777.648] f0 00 20 33 01 10 6f 07 40 64 f7
[16777.655] f0 00 20 33 01 10 6f 07 41 00 f7
[16777.663] f0 00 20 33 01 10 6f 07 42 40 f7
[16777.669] f0 00 20 33 01 10 6f 07 43 64 f7
[16777.677] f0 00 20 33 01 10 6f 07 44 01 f7
[16777.685] f0 00 20 33 01 10 6f 07 45 40 f7
[16777.692] f0 00 20 33 01 10 6f 07 46 64 f7
[16777.699] f0 00 20 33 01 10 6f 07 47 00 f7
[16777.706] f0 00 20 33 01 10 6f 07 48 40 f7
[16777.714] f0 00 20 33 01 10 6f 07 49 64 f7
[16777.720] f0 00 20 33 01 10 6f 07 4a 01 f7
[16777.728] f0 00 20 33 01 10 6f 07 4b 40 f7
[16777.735] f0 00 20 33 01 10 6f 07 4c 64 f7
[16777.743] f0 00 20 33 01 10 6f 07 4d 00 f7
[16777.750] f0 00 20 33 01 10 6f 07 4e 40 f7
[16777.757] f0 00 20 33 01 10 6f 07 4f 64 f7
[16777.764] f0 00 20 33 01 10 6f 07 50 01 f7
[16777.772] f0 00 20 33 01 10 6f 07 51 40 f7
[16777.779] f0 00 20 33 01 10 6f 07 52 64 f7
[16777.786] f0 00 20 33 01 10 6f 07 53 00 f7
[16777.793] f0 00 20 33 01 10 6f 07 54 40 f7
[16777.801] f0 00 20 33 01 10 6f 07 55 64 f7
[16777.808] f0 00 20 33 01 10 6f 07 56 01 f7
[16777.815] f0 00 20 33 01 10 6f 07 57 40 f7
[16777.822] f0 00 20 33 01 10 6f 07 58 64 f7
[16777.830] f0 00 20 33 01 10 6f 07 59 00 f7
[16777.837] f0 00 20 33 01 10 6f 07 5a 40 f7
[16777.844] f0 00 20 33 01 10 6f 07 5b 64 f7
[16777.851] f0 00 20 33 01 10 6f 07 5c 01 f7
[16777.859] f0 00 20 33 01 10 6f 07 5d 40 f7
[16777.866] f0 00 20 33 01 10 6f 07 5e 64 f7
[16777.873] f0 00 20 33 01 10 6f 07 5f 00 f7
[16777.880] f0 00 20 33 01 10 6f 07 78 00 f7
[16777.888] f0 00 20 33 01 10 6f 07 79 30 f7
[16777.895] f0 00 20 33 01 10 6f 07 7a 7f f7
[16777.902] f0 00 20 33 01 10 6f 07 7b 40 f7
[16777.909] f0 00 20 33 01 10 6f 07 7c 00 f7
[16777.917] f0 00 20 33 01 10 6f 07 7d 01 f7
[16777.924] f0 00 20 33 01 10 6f 07 7e 00 f7
[16777.931] f0 00 20 33 01 10 6f 07 7f 00 f7
so, as i see it, i have to somehow ditch the dump scenario and just accept parameter jumps when using the NG-encoders. i think it is not that big of a deal, but a bit of a mystery anyway.
thank you for putting your time into this :smile:
okay, the sysex stuff seems to be global parameter settings. the virus has the parameters distributed over 3 “pages”.
  • page A - low page (patch specific)
  • page B - high page (patch specific)
  • page C (global settings)
Page C contents Multi parameters and Global parameters. These parameters are sent and received only by SysEx Parameter Change.
so, one can not set the virus to circumvent transmitting the global settings.
nun ja -
