Iam new to this forum , and hence i dont know wether this is the right place to post this messege .
I have got three keyboards with MIDI and I want to connect all the three to my 1X1 USB MIDI interface so that I can play a virtual pipe organ. for that I need to make a MIDI merge with 5 in and one out( I need to MIDIfy my pedalboard also.)
Can any one please tell me how to make a MIDI merger (5X1) and MIDI board for Pedalboard and stop switches…
While you can build a MIDI Merge using the MidiBox, it is more cost effective to buy a MIDI to USB interface with the required number of inputs if all you need is the merge. BTW, 3 keyboards plus pedal is 4 MIDI In. If you can get by with 4 Inputs rather than 5, you will save quite a bit of money. If you need 5, then you probably should buy 4 and use your existing 1x1 USB for the 5th input.
