MIDI Merge Help
Hi All,
I’m building a 2-core MIDIO 128, and have everything up and running…EXCEPT, the two refuse to merge.  Each core works perfectly independently, and I get the appropriate MIDI data output. I’ve created new .syx files for each core with merge enabled (I’ve tried only doing one at a time, as well), and even had a friend send me known-working .syx files for a 2-core setup like mine. Still nothing! Core 0 (outputting to the PC) works just fine when the two are daisy-chained, but core 1 does nothing.
Hi, are the device IDs set correctly (that is, if you are using 8-bit cores)?
does this mean, that Core0 is able to send MIDI events through the second core to your PC?
