midi merge function
Hi buddies
maybe missed something but is there a command line (e.g MERGER_On()) in C for enabling the merge function on the core when writing a custom application ? I would like to connect a keyboard to a core and that this core send all events from the kbd to the output.
if not i will use the example given by thorsten in the C programming examples section ,like this :
void MPROC_NotifyReceivedEvnt(
  unsigned char evnt0, unsigned char evnt1, unsigned char evnt2) __wparam
        MIOS_MIDI_TxBufferPut(evnt0);
        MIOS_MIDI_TxBufferPut(evnt1);
        MIOS_MIDI_TxBufferPut(evnt2);
yes there is  :wink:
MIOS_MIDI_MergerSet
C_DECLARATION
void MIOS_MIDI_MergerSet(unsigned char mode)
DESCRIPTION
configures the integrated MIDI merger following Merger IDs are provided:
0x00: MIOS_MIDI_MERGER_DISABLED (merger disabled)
0x01: MIOS_MIDI_MERGER_ENABLED (merger enabled)
0x02: MIOS_MIDI_MERGER_MBLINK_EP (MIDIbox Link End Point)
0x03: MIOS_MIDI_MERGER_MBLINK_FP (MIDIbox Link Forwarding Point)
C_EXAMPLE
  // configure the MIDIbox as MIDIbox Link End Point
  // (means: merger enabled only for events which has
  // been generated by another MIDIbox which is configured
  // as MIDIbox Link Forwarding Point)
  MIOS_MIDI_MergerSet(MIOS_MIDI_MERGER_ENABLED);
Regards,
Michael
