Great idea .. I use a professional NSI MIDI 616 Memory Lighting Control Console for my theatrical productions that works well as a source to control stage lighting coupled with a simple mini MIDI keyboard plugged into the lighting controller (that also can work as a stand-alone light controller without MIDI) to control up to 16 circuits of theatre lights.
Simply set a scene with up to 16 lights, then save that as a keystroke (say, C), then set another scene and save that as another keystroke (say C#) and another, (say, D), etc. You get the point.
It’s sort of like registering an organ with pistons that you punch to energize various pre-selected ranks of pipes, except you can set the intensity of each lamp individually in the light mix, whereas an organ sets the stoptab, but the swell pedal control intensity.
I can hardly wait to complete my own organ MIDIbox project, but I digress …
Then to perform the light cues for Act 1, Scene 1, simply “play” the C note on the synthesizer.
To transition to Act 1, Scene 2, simply “Play” the C# note of the synthesizer, etc. as each of these are set into MIDI memory . . . Saves a lot of fidgiting once the scenes have been configured to simply play a note on a keyboard instead of setting all 16 channels of lights.
If this can be accomplished via DIY MidiBoxes, what a breakthru for community theatre without the need for more than 16 channels of light circuits, or churches that transition from worship to weddings to baptisms, or whatever, by simply configuring and saving pre-set lighting cues on a synth keyboard or a MIDI button on a MiniBox.
By the way, these light mixers (slide faders that resemble a recording studio sound mixing console) simply send control TRIGGERS to master dimmer boxes (using lengths of microphone cords to interface the mixer to the dimmer boxes) … they do not directly control light bulbs.
pk
Hi
… my idea is a modular midi-controlled light controller … that can be controlled by midi control surface or sequencer (or computer, of course).
The stuff I don’t know is how to interface light dimmers/LED drivers with MIOS.
Gimzo
