MIDI IN fonctions?? (MF & MTC)
hi all!
I plan to design a nice little  midibox in a canibalized genexxa body.
Big 6digit MidiTimeCode (bars/beats/tics, whatever)would like really nice above the transport controls
I suppose this would require adding  midimon to the mb64, only would it need its own Core or can 1 midibox core be a midibox and a time code “displayer” (using the midibox midi IN)at the same time?
the other question is: will my motorfaders respond to sequencer automated tracks (moving automatically if I load a new song into the software sequencer, etc..)?
I hope i’m not confusing everybody here, i’m unfamiliar in this domain :-[
I’ll post a prototype pic later on to illustrate thoughts…
Don’t forget your midiBoxing gloves!
Not sure about the MTC (but I would like to know)
As far as the MF’s (motorfaders that is!) go: of course that is one of the main advantage for me of having motorfaders, whenever you open a new track the faders jump straight to the correct position!
peace
LO
As far as the MTC and other midibox functions go, with a MIOS bassed system this should be easy.  I don’t know about the older non MIOS systems though.
John S.
I’ve programmed the MTC and leddigits handler in a modular way - just integrate leddigits.inc, mtc.inc, convert_bin2bcd.inc and parts of mon_mtc.inc into the MB64 application (read the file headers!) and call the handler from USER_MPROC_NotifyReceivedByte - this hook can be found in main.asm:
        ;; call MTC handler
        call    MON_MTC_NotifyReceivedByte
        ;; -> continue at MB64 sysex parser
        goto    MB64_SYSEX_Parser
thanks Thorsten! Its going to look smashing!
(currently working on a nice 3d prototype, I’ll send you a pic if you don’t mid)
kind regards!
-Alex
“midibox macht frei!”
