I have one problem… I make MIDI-COM interface for comunication whith MIDI device whith PC. I tested in MIDI-OX and HYPERterminal and this software is work ok whith this interface, when I use MIDI-COM with Logic Audio and other software is something wrong. When Midi device send something data string and then Logic Audio is receive this data and answer to Midi Device it is ok, but then midi device is send another data is Logic not receive data, but midi device can receceive from Logic… and when I try close Logic Audio I can’t close… I dont know that this that ?, I used YAMAHA CBX Drive V2.0 and tested in ROLAND MIDI cOM drive and results is that same… Why in MIDI-OX and Hyperterminal is work ok… Please Help Me…
first you should check the “\windows\win.ini” file where you can find a special configuration block for Logic. All MIDI interfaces should be marked with 1, if especially your COM interface is marked with 7, it would mean that Logic ignores it.
Just remove the whole block so that Logic checks the interfaces again.
If it still doesn’t work, try the Kawai K5000 driver:
