Hello, sorry if it’s a newbie question …
Can the midi Channel be affected Separately to each CC ?
Can it be done in live ? I mean can i change the midi channel directly when the midibox is turned ON ?
Or must it be programmed in the Mios ?
thanks
thanks
hey;
you are talking about MB64(e) right?
yes you can configure all those things when your machine is running.
if you have an lcd it’s easy; otherwise you have to configure it with a PC and vmidibox
good luck
I’m not particularly talking about MB64e
I’m building a midibox with all I can put on it … LCD , Potentiometers, Encoders , switches and breath controller …
I looked at the MB 64e and i was suprised with the features … I didn’t know that some midibox programm had menu navigation etc …
Do you think I can adapt the MB64e programmation (with menus, channel select, midi learn …) with some potentiometers added to it ???
thanks
yeah i think you can ![]()
just read up on how to configure the application with MPLAB, open the project file in the MB64e folder, and read/edit the main.asm file.
once you get the idea it’s quite easy
cheers, marcel
ok ! thanks for all
