Just wondering if someone had a simple midi in out to computer game port wiring diagram
MIDIFARM has the pin out/optoisolator schematic as well as several midi pages. there are several variations out there but all should include an opto-isolator on the rx line and some sort of gate as a buffer on the tx line… Monte
Ive been using this for quite a while, and havn´t had any problem.
http://users.chariot.net.au/~gmarts/miditech.htm
js
Right I have a keyboard that puts out midi, but instead of having a midi plug it goes straight to a sound card 15 pin plug.
I have just finished my controller and want to run the keyboard at the same time so it needs a midi connection not a 15 pin connection.
I cut the connector up found wires red shield and white I check them on the coonection and they are GRD +V and midi in, when it tried to wire up a midi plug I get nothing, have I missed something really obvious, please can you help
Steve
Im pretty sure that the cable that you´ve got is the same as the one that came with my Miditech midi-keyboard. Â
As far as I can remember does my cable use pin 1 & 3 instead of 4 & 5 on the midi-jack. I think that they made it this way to save some $. They´ve left out the optoisolator and supplys the keyboard with power from the gameport.
I guess it would work with another cable like this one: http://www.hardwarebook.net/cable/misc/midi.html
Another thing, does you controller have a midimerger, if not you need two midi inputs (one for the keyboard and one for the controller)
Hope that this could be any help to you!
js
