I have been using a MidiBox for some time and it appeared to stop working so I bought a new one.
It doesn’t really have a name, just USB MIDI BOX 4i4o + Merge 2i4o.
I have four keyboards (one is a pedalboard).
The MidiBox only works on Channel One.
Each of the keyboards works okay if it is plugged into Channel One so there is obviously nothing wrong with the keyboards.
Is there some setting somewhere that I may have missed or changed inadvertently?
Help would be appreciated.
I have attached a PDF of the manual that came with the MidiBox.
[MidiBox.pdf](< base_url >/applications/core/interface/file/attachment.php?id=11548)
novski
August 18, 2014, 5:18am
2
Seams like the manual is not complet. There are 6 modes but just one is described…
Midibox is a opensource platform that works with Do it yourself hardware. Your part carrys the same name but is a commercial product.
The other five modes are for Thru and Merge.
The PDF I included is the only mode for a USB output.
What novski says. Try to get support from the manufacturer. Although the name is the same, we are DIY people and create our own boxes. We are not related to your commercial box in any way.
novski
August 19, 2014, 1:02pm
5
I think you simply have to choose the midi port in your os… Look in to the preferencies of your program or your os first…
